1990 KDX200F SR - Rear brake line guides / eyelet
Has thanked: 184 times
Re: 1990 KDX200F SR - Rear brake line guides / eyelet
USA KIPS covers did not get the vent. Google for KDX125 or similar non-USA models. That tube is a lot longer. My KX250 and YZ250 have such vents.
rickvs355
Country: Australia
Post by rickvs355 »
Ok thanks. Still didn't get much from google. From what i can gather from a few forum discussions is that the hose is supposed to run down the front of the frame and just drip on the floor. I will set it up this way again.
cheers
Rick
That's what I think, just runs down the front and drips.
rickvs355
Country: Australia
Post by rickvs355 »
thanks
You're welcome. I wish we had that part here.
rickvs355
Country: Australia
Post by rickvs355 »
FYI - Tried to unscrew the lugs and they just snapped off. Looks like they may have been glued in there. Swing arm will need to come off to tap the threads, bugger. Anyway I can give it a tidy up and respray whilst it is off
Well, dang. Thanks for giving it a try.
hi-def
Country: New Zealand
Post by hi-def »
Good to know, I was pondering changing my guides when I put new lines on as there were a bit loose on the coarse thread but couldn't be bothered. Next time I have it all apart I'll do the same and drill and tap for the newer style ones.
rickvs355
Country: Australia
Post by rickvs355 »
Update showing screw type guides installed
Wow. That looks so much better than the stock ones. Great job!
hi-def
Post by hi-def »
Looks great, well done
