KDX250 hybrid - what chassis?
Has thanked: 30 times
Been thanked: 44 times
Just thinking ahead here. It seems the one downfall of the KDX250 was the chassis setup. I'm thinking of possibly building a hybrid using the KDX250 engine in the future.
So, what chassis would work for this? The KX125 like 200/220 hybrids or would I need to step up to a KX250 chassis? What about the KX250F/450F chassis? Yeah, I know the 4t bikes would need the frame cut and TIG welded for the 2t pipe but other than that, what other pro/cons to them?
KarlP
Post by KarlP »
I think any 2000+ chassis can be made to work.
I personally think I would go with a steel frame if I was going to do another.
'08 KTM200xc
KX100 for the boy
Tedh98
Been thanked: 2 times
Post by Tedh98 »
How much larger is the 250 motor over the 220/200?
Has thanked: 10 times
Been thanked: 17 times
Considerably larger. The kdx200 engine was designed after an early model kx125 engine, the KDX250 engine is basically a de-tuned kx250 power plant.
I think you'd be hard pressed to fit it into a KX125. If it were me, I would look for a kx250 roller. Should be a relatively easy swap.
Tedh98
Post by Tedh98 »
I would agree then on going with a 250 roller.
With the engine in place, there really isn't that much room between it and the downtubes near the exhaust.
KX250 it is. Thanks for the input.
ldspowersports
Post by ldspowersports »
How is the build coming along?
Luke
http://www.woodsriderparts.com
My 200 or the 250? The 200 is stalled right now due to my car taking a dump and the 250 won't get started until I find a reasonable priced roller sometime down the road. I can't hardly find KX250's around here. Lots of Yamaha YZ's though. Maybe a YZ-KDX250 hybrid?
I think the YZ would be doable.
Yeah, but where can I find green plastics for it! :mrgreen:
No green, but black and white would look good!
Found a good deal on a '06 KX25F chassis with a blown top end. (I can feel juliend cringing right about now!) Hey, the weight that year for the KX250 and F were the same. That would lead me to believe that the F frame is actually lighter than the KX steel since the 4t engine should be heavier than the 2t.
Anyways, trying to decide if I want to go with it or not. It would make an awesome hybrid for the KDX250 engine if it would fit. Anybody have a clue if it would? Also, I know the frame would have to be cut and welded, the radiator outlet on the left side would have to be modified, the usual engine mounts, and swingarm/rear case mods but is there anything else?
