RB STEM SWAPS
Indawoods
Creator and Founder
Creator and Founder
RB STEM SWAPS
Post by Indawoods »
Guys,
Ron has perfected the conversion process for the stem swap and spacer. He goes far beond of what your local machinist will do and for a much better price making it an unbelievable value.
Don't even think about it... just do it.
http://www.rb-designs.com/KDX-KX-Stem-Swap.htm
Varmint
Post by Varmint »
Nice! That right there is a sweet deal!
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
rbates9
Post by rbates9 »
Has any one asked him about the wheel spacers to use a kdx front wheel? http://kdxrider.net/forums/viewtopic.php?t=9504
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Ron is a member here...RBD ... you can also contact him through his website. Ron is a fantastic machinist and I am sure he would look into what you want done and quote you a price.
Little Jeff
Post by Little Jeff »
+1 on Ron's work. Did a great job on my KDX stuff, carb head and stem swap for the KX forks. He also machined the head on my KTM 300 to. Just a great guy to work with.
Little Jeff
Riding with your buddies and an adventure, riding with certain individuals is an ordeal.
motojunkie01
Post by motojunkie01 »
Oh ya ! Sending my stuff out this week .
rbates9
Post by rbates9 »
Well, the axle mod has been completed by RB. The parts fit great. All work is top notch. The 2000 kx forks that I have now accept a KDX wheel like it was meant to be there.
[IMG::]http://i1093.photobucket.com/albums/i43 ... 0_0161.jpg[/img]
Mr. Wibbens
Post by Mr. Wibbens »
So what did all that run ya?
rbates9
Post by rbates9 »
Mr. Wibbens wrote:So what did all that run ya?
Not to bad, not to bad at all. RB will be posting the mod on his web site with pricing info in a few days.
It is already there.
rbates9
Post by rbates9 »
http://rb-designs.com/
Go to KDX-KX stem mod.
Mr. Wibbens
I see he's no longer offering the axle modification service
That was quick :wink:
Has thanked: 30 times
Been thanked: 44 times
Bummer but I understand his reasoning.
Mr. Wibbens
Yup it'd be a freaking nighmare
turner
Re: RB STEM SWAPS
Post by turner »
anyone know how tight the stem needs to be in the tripple clamp to require knurling? my cr125 tripple and kdx are exactly 30.17mm. it fits tight but do i need extra?
diymirage
Re: RB STEM SWAPS
Post by diymirage »
shoot Ron a PM, hes on here
but to be honoust, id send both pieces in to him and let him worry about it
-1997 KDX 220 project bike
rbates9
Re: RB STEM SWAPS
Post by rbates9 »
turner wrote:anyone know how tight the stem needs to be in the tripple clamp to require knurling? my cr125 tripple and kdx are exactly 30.17mm. it fits tight but do i need extra?
If you can tap it in with ease then it is probably too loose. If there is a slight press fit then you should be good. I don't belive that the tolerance is that critical. When the stem is in the lower clamp the snap ring will keep it from being pulled up thru the lower clamp and the preload will keep the stem tight in the clamps. The press fit of the lower bearing against the lower clamp is going to keep things in place as well. The forks will hold everything in place once the assembly is installed on the bike. To me a snug fit is good enough. a serious press fit would be nice but I don't think that it is that critical. As long as the stem isn't loose in the lower clamp then I would think that you should be good to go.
turner
Re: RB STEM SWAPS
Post by turner »
alright that what i was thinking. i sent rb an email about the spacer for the upper clamp and if knurling was needed. now all i got to do is find a lower bearing.
soup-n-sandwich
Re: RB STEM SWAPS
Post by soup-n-sandwich »
Hi guys,
Now that Ron is retired is there anyone else that can adapt the forks from a 2009 KX450F to the KDX's stem? This has been a problem for me for a while.
Any thoughts or recommendations to find someone that can do this type of work?
C
Has thanked: 240 times
Been thanked: 119 times
Re: RB STEM SWAPS
I've been thinking that perhaps Honda CRF250/450 & late 2-stroke CR steering stems (Showa forks) may perhaps be long enough to run with the appropriate conversion bearing size upper bearing, but I haven't been able to confirm this due to my obsession with '98 RM125 forks... Also on the KYB side, I'm fairly certain chopperpilot or someone else on here just recently confirmed that Yamaha YZ stems of recent years (probably '06+?) can be run in the KDX frames.
EDIT - this has all been confirmed now that the later Honda CR250R and all CRF250 and CRF450 steering stones are nearly the perfect length for a KDX, as well as the YZ250 2-stroke and some YZ450 4 strokes. Later YZ250F use the medium like Yamaha stem which just makes it on a kdx, as well as some of the 450's. The Yamaha and KX forks use a 28 mm inside diameter stem bearing so you're still stuck with a generic Chinese bearing although you can use the 30x47x12 and have a simple adapter machine to increase the diameter of the bearing from 30 down to 28 mm, with a flange on the top that will slip over the seal and bearing, but you will still need a 3 mm tall spacer 47 mm OD to go under the bearing race on either set up to keep the seal flush with the top of the frame.
This is all due to 28mm & 30mm i.d. bearing sizes becoming available in 12mm tall heights and KDX upper bearing o.d. sizes in recent years, although they aren't the most common bearing sizes to say the least, you can get them readily through AllBalls/PivotWorks/QuadBoss & Pyramid Parts etc.
It always baffled me that people would go to great lengths to swap out an aluminum steering stem for a heavy steel atem thathas to be knurled to increase the o.d. to press fit tolerances, when there perhaps were otger options to explore like this in order to run aluminum steering stems that cone with the donor triples....
Granted a lot of triples 1996-early/mid- 2000's do not have the correct height to be compatible with the KDX frames. In order to use those triples, it's still mandatory to do a stem swap.
