Believe my clutch basket is wasted ROUND2 - need help
turtle
Post by turtle »
My clutch basket has some deep grooves in it, a good millimeter or more. I think the basket is beyond filing, but I don't know for sure so I'm looking for opinions. Is it worth salvaging? If it is toast, is there anywhere else to get a basket besides Fredette or OEM?
Also, on the hub nut, I searched and have some ideas for holding the basket while loosening the nut, but what's the best way?
Finally, is applying increasing torque (with a pipe on a breaker bar if needed) the way to go to loosen the hub nut, or is hitting the breaker with a hammer the better idea to break it loose?
I have posted this before but I own a Kawaski Concours street bike and there is a great forum for that bike. You can learn anything and everyting about the Concours there. I never expected to find the same thing when I bought my KDX but I think I have. Y'all rock :supz: and I appreciate the help while I am learning my way around the KDX. Thanks!
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
Been thanked: 19 times
Hit the nut with an impact wrench, or do the penny trick in the gears.
Has thanked: 34 times
Been thanked: 57 times
Impact wrench. Takes about 5 seconds with the cheap electric Harbor Freight one I have.
I don't know of anyone other than Fredette and OEM. Sorry.
frankenschwinn
Post by frankenschwinn »
SS109 wrote:Impact wrench. Takes about 5 seconds with the cheap electric Harbor Freight one I have.
+1
Mr. Wibbens
Post by Mr. Wibbens »
If it was me I'd file it :wink:
Actually I'd use my Dremel
Rick
Post by Rick »
You can remove the plates, and file it in posistion if need be. Just shove some rags in the case to catch the shavings. It will take more time though, and you have to be real carefull that the shavings dont go in the case. Add new oil when done, ride it for a few minutes. Change the oil again. Check for metal in the oil. Should be good to go.
Yes, they really do let me drive the Train!
1991 KDX 250 $Sold but not forgotten....
1996 Suzuki DR 350 $Sold!
2002 Honda CR 250 worth more than my house at this point........ :-)
2004 DR 650se Road Warrior
2002 DL1000 V-STROM
KarlP
Post by KarlP »
I'D file that basket without hesitation.
I would pull that pushrod in the center of the clutch and make sure you have the shim that goes under it if there is one. Put 'em away safely, they are easily lost in the shuffle.
I've been using XR400 friction plates.
'08 KTM200xc
KX100 for the boy
gregp
Post by gregp »
I have filed plenty of baskets in my day, and that is a good candidate for that practice - however, you should be aware that filing the basket will accelerate the wear at that spot, and the basket will soon be gooved again - much quicker than those originally appeared. I suspect this is because the plates have more room to slap back and forth...
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
turtle
Post by turtle »
gregp wrote:I have filed plenty of baskets in my day, and that is a good candidate for that practice - however, you should be aware that filing the basket will accelerate the wear at that spot, and the basket will soon be gooved again - much quicker than those originally appeared. I suspect this is because the plates have more room to slap back and forth...
Hmm ... makes sense. How soon is soon? I'd rather stay out of there for a while once it's done.
Is the FRP basket any more durable than the stocker?
Bill
Central IL
2004 KDX220R
Coop
Post by Coop »
Any deeper than .020" and it needs replaced in my opinion.
"Twenty years from now, you will be more disappointed by the things that you didn't do than by the ones you did do" - Mark Twain
2003 KDX200
David_L6
Post by David_L6 »
I'd replace that basket.
The FRP basket is more durable. I don't think it would ever groove.
Mr. Wibbens
Mine was grooved like that back in '03
I carefully removed the largest grooves with my dremel then filed it square
It still looks great today
Mr. Wibbens wrote:Mine was grooved like that back in '03
I know you LOVE to reuse old parts, but cmon that's just ridiculous....
Coop
Post by Coop »
LOL I knew that was coming... :grin:
2003 KDX200
scheckaet
Post by scheckaet »
I don't see the point in trashing something that could still give you another year of use (maybe more, maybe less).
What do you have to lose? it shouldn't take too long to remove the clutch, file that smooth and go ride.
There is an article on thumpertalk about filing the clutch basket in the how to section.
I'd get the new basket as a back up when money is available, but that's just me.
scheckaet
Post by scheckaet »
Slick_Nick wrote:>|<>QBB<
Aren't you the one polishing rusty old bearings... :mrgreen:
Mr. Wibbens
it's nothing compared to your krusty old bearings
Mr. Wibbens wrote:it's nothing compared to your krusty old bearings
Krusty is the new clean! I was just ahead of the trend! ;)
Varmint
Post by Varmint »
Possibly stupid question but I need to ask so I can learn.
Where is the damage I'm looking for here? Is is the four grooves in the basket where the plate tabs have carved themselves in?
What problem does this cause? Plates do not seperate easily?
Your solution is to file these grooves away. Does this make the opening bigger allowing for slop in the plates?
Thanks!
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
