Counter sprocket leak
flyingbrick
Post by flyingbrick »
Hey everyone!
New to dirtbike maint and have been really loving my 01 220, just a question though, it seems to leak a drop or two of oil out of trans where the counter sprocket is, is this a common problem?
How difficult is it to fix?
I wouldn't mind that much but it gets oil spots on the ground and it slings oil everywhere making it a pain to keep the engine/trans clean...
I looked on bike bandit and it looks like its only 2 o-rings that seal that shaft... is that it? Can i just remove sprocket as to change it then just change the seals?
Thanks for the help!
Joe
Has thanked: 5 times
Been thanked: 12 times
I believe it's 2 o-rings and a mechanical seal. You can change them all from the outside after you remove the CS sprocket.
flyingbrick
i don't see a seal on the bikebandit diagram, anyone have a part number or anything like for it?
thanks!
Lookin in the wrong place then. Check the crankcases fiche.
92050:
OIL SEAL TB3040
864475 (5124-001)
0-99 $12.52
Mr. Wibbens
Post by Mr. Wibbens »
gregp
Post by gregp »
Most bikes have an O-ring or two under a sleeve, and a regular oil seal that is pressed into the case, that seals against the OD of the sleeve.
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
gregp
Post by gregp »
gregp
Post by gregp »
The O-rings and sleeve can be seen here (part # 92143 is the sleeve, part # 92055 are the O-Rings):
http://www.bikebandit.com/houseofmotorc ... #sch313743
flyingbrick
Thanks a ton guys!
Just ordered everything so i can fix this and change my oil soon!
flyingbrick
found a write-up for doing this on a kdx, dunno if it'll help anyone in the future.
kinda sucked having to open all the pics manually though
http://www.thumpertalk.com/forum/archiv ... 46957.html
kevfort19
Post by kevfort19 »
Beautiful!!!
KDX 220 2001 =)
Don'T drink and drive...just give some gas and fly :D
dfeckel
Post by dfeckel »
I bpought a cheapie seal pulling tool at the local auto parts store, which makes removing the seal from the motor 1000% easier than prying with screwdrivers and picking with needlenose pliers.
It looks much like this one:
http://www.harborfreight.com/seal-puller-35556.html
David Eckel
moto_psycho
Post by moto_psycho »
seal size is 40x62x7
