used engine?
tydev95
used engine?
since my engine needs $350 to $400 in work, i'm considering a used e series engine on craigslist. the guy said he put in a new piston, and it has great compression. however, he has no way to show me that it runs. is there anything i should look out for? the engine is $250 with a carb and wiring.
- scheckaet
u gonna have to modify the H frame and get different pipe ...
what is wrong with your engine? top end? bottom end?
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- rbates9
- Been thanked: 2 times
IMHO the money spent on fixing what you have would be less than the headache of swapping to a different engine. Plus you will know for sure what you have. If you have an H and try to put an E engine in it there will be a lot of unexpected cost that will probably take you over what you would spend in the first place. If it is just the money, I would go with fixing what you have. If there is other reasons, go for it. I have never road an E bike but a lot of people like them better. But a lot of people have issues with the KIPS from what I have read.
- OLHILLBILLY
- OLHILLBILLY
His bike is a '93, motor he's looking at is a '94. Is that when they changed frames? Thought it was '95.rbates9 wrote:IMHO the money spent on fixing what you have would be less than the headache of swapping to a different engine. Plus you will know for sure what you have. If you have an H and try to put an E engine in it there will be a lot of unexpected cost that will probably take you over what you would spend in the first place. If it is just the money, I would go with fixing what you have. If there is other reasons, go for it. I have never road an E bike but a lot of people like them better. But a lot of people have issues with the KIPS from what I have read.
2004 KDX 200.. Coupla mods
2009 KX250F.. Track Star
2007 Hayabusa.. Street Madness
tydev95
my bike needs a top end, cylinder replate, and left powervalve. i'm fine with spending the extra $100 to fix the engine i have now, but i'm not really confident in putting it back together because this is the first dirt bike engine i've ever worked on. i really don't want to have something break and waste all of the money i put into it.
- rbates9
You are right it was 95. I was just going by the previous post saying it was going into an H frame. But still sticking with what you know is better than taking a chance on what you don't.OLHILLBILLY wrote:>|<>QBB<His bike is a '93, motor he's looking at is a '94. Is that when they changed frames? Thought it was '95.rbates9 wrote:IMHO the money spent on fixing what you have would be less than the headache of swapping to a different engine. Plus you will know for sure what you have. If you have an H and try to put an E engine in it there will be a lot of unexpected cost that will probably take you over what you would spend in the first place. If it is just the money, I would go with fixing what you have. If there is other reasons, go for it. I have never road an E bike but a lot of people like them better. But a lot of people have issues with the KIPS from what I have read.
- scheckaet
There's nothing to it really, buying a used engine with unknown history could cost u a lot more than doing the top end yourself.tydev95 wrote:my bike needs a top end, cylinder replate, and left powervalve. i'm fine with spending the extra $100 to fix the engine i have now, but i'm not really confident in putting it back together because this is the first dirt bike engine i've ever worked on. i really don't want to have something break and waste all of the money i put into it.
The only thing to watch out for is to support the kips actuator shaft when removing the cylinder, that's about it.
Everything is fairly straightforward with the manual and this website if u have any questions.
When u take it apart, take your time, take pictures and if u are not sure about anything let us know.
I did the 1st top end with this bike too, and it wasn't that bad at all.
+ once u done it:
satisfaction to have it done yourself
piece of mind that it was done the RIGHT WAY.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- ihatefalling
True that....do it yourself. If you get in trouble post some pics here on KDXR and the guys will help you. PLUS.....what you don't know about that motor can hurt you. It could have half way stripped bolt holes, worn bearings, chipped gears, a clip missing, blah blah blah
2005 KDX 220
R&B Carb Mod
R&B Head Mod
Fork Swap - 99 KX125 Valved for B woods plush
FMF Gnarley
Airbox Mod
Tagged
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
tydev95
i went to look at the engine today, it was a p.o.s., the shaft that the shifter goes onto was twisted, it had the wrong spark plug forced into the head , all of the kips were broken, and the piston had chunks missing from it. and you should've seen the rest of the bike. it looked like someone ran it over a few times. but then again the guy had a ton of broken down bikes just sitting outside
