Uprating the generator?
moto_psycho
Post by moto_psycho »
Any tried and tested way you guys have done this?
gregp
Post by gregp »
There used to be some 60 or 70 watt coils available, I think, and Baja Designs will rewind your stock stator to power their dual sport kit. I was able to power their dual sport kit by using LED bulbs in the directionals and tail light, and a Tusk "Blue" 35w bulb in the headlight. It all works fine on the stock stator (no battery).
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
scheckaet
Post by scheckaet »
Inda was working on dat awhile back
Been thanked: 17 times
I rewound my stock stator with good results.
gregp
Post by gregp »
That is interesting, Nick. Can you tell us what was involved in that process - like, what gauge wire you used, how many wraps, and where you obtained it? I presume that the wire can be purchased at Radio Shack, but it has to be coated, correct?
I would like to be able to power a 55-60w headlight...
Check my build thread here or on thumpertalk. Can't remember off the top of my head but I believe it was 17-ga coated magnet wire.
TWMOODY
Post by TWMOODY »
gregp wrote:That is interesting, Nick. Can you tell us what was involved in that process - like, what gauge wire you used, how many wraps, and where you obtained it? I presume that the wire can be purchased at Radio Shack, but it has to be coated, correct?
You can buy the wire you want at any electrical motor shop.
I rewound one portion of a stator many years ago when I was
poor and could not afford 500 bucks for the stator/flywheel assy.
I bought a spool of coated wire, put a dowel rod through the center
and put it between 2 chairs in my kitchen. I fed the wire through a
hard plastic straw (as a feeder) and wound it up.
I took quite a while and when I was done I put a epoxy coating on
the out side.
It worked fine for the 2-3 years that I owned the bike.
That was on a late 70's XT500.
gregp
Post by gregp »
Do you have any idea what gauge wire you used? There is a formula to calculate how many watts you can get, but the gauge of the wire, and the number of wraps is critical to the calculation - I think...
moto_psycho
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
I have a couple spools of that 17 ga. coated wire.... I never had to try it yet.... shouldn't be rocket surgery...
