I've got the Rev Loc installed as per the the directions. but the clutch pull feels waaay hard. I've yet to start the bike (top end will be done 2morrow).
I haven't adjusted the cable yet, so that's the next step.
Question is, should the clutch pull be so hard? If so, constant tension on that cable is gonna stretch it out real quick.
Rev Lock Install Question
- KDX4ID
CURRENT FLEET
2008 KTM 990 Adventure...Alaska here I come!
2010 KTM 300 XCW... stop me before I buy again!
2005 KDX220... single track sweetie
2007 KTM 450 EXC... my baby
2008 KTM Superduke... Canyon Carver
1996 Honda 650L... GONE but not forgotten
http://www.friendsoftruckeetrails.org
Check to see that the washer behind the center insert hasn't fell behind the clutch pack. This is commonly the problem.
- KDX4ID
Found the problem, I left one of the judder springs on top of the pack. Doooh!
Good news is... got the top end in, started it and all looks/sounds good. 2morrow I'll play with the clutch adjustments and hopefully go for a ride in the afternoon.
CURRENT FLEET
grumpyman
is this washer one of the steel plates from the dyna kit or is it one of the two washers behind the 22mm nut
my kit had nothing but the clutch pack and some extra springs for the dyna ring
sorry i am not clear on "center insert"
The washer is not part of the Dtna Ring package. The center insert I am referring to is the cast piece that the nut holds down... part number 13087.
Part number 99200 is the washer I am referring too.
grumpyman
