Hi, I'm new to 2 strokes, but do understand the concept of the PowerBand. I just bought a '99 220 for some green lane trail riding here in the UK. So here's my challenge - I've taken the bike for a brief run and I'm astonished at the hit of the PowerBand. First time out I was close to sliding off the back in 1st, 2nd & 3rd!
The guy I bought it off said it was a practice bike for a semi-pro rider, so may of had some tweeks, I know the piston has been exchanged. The bike starts 2nd / 3rd kick, seem to run smoothly from cold to warm, on the road can have a slight tendency to bog a little if I don't get the revs right when pulling away, but WOW when it hits it hits, then dies very quick. So the PowerBand surge is a big 1 to 2 second hit.
I'm running a standard exhaust system, cos I got to get it through the UK MoT test for road use, so have exchanged the noisy Doma race system that was on it.
From what I've read on this site, the 220 is meant to be a little calmer and smoother that I've experienced. Unfortunately the big bang power rush isn't what I need for trail riding.
So I'm looking for advice where to start to calm things down a little, I'm guessing jetting and reeds are the place to start?? Any other ideas? Or do I just need to learn to ride it better?!
'99 KDX 220 with Vicious PowerBand!
Lovejoy
What are the teeth counts on your sprockets?
If it is bogging when you are taking off... it sounds like a lean bog which is why it is so violent... Check your jetting.
- Mr. Wibbens
Vicious PowerBand ??
On a 220 ??
There's something wrong with it
On a 220 ??
Lovejoy
Right, carb stripped - this is what I've found:
Main jet 145, pilot jet 42, and needle slider set at stock third from top.
As I have no replacement jets at present I'm gonna put it back together moving the e clip on the needle slider up one notch which will lean out the midrange (according to Cyclepedia) and play with the pilot air mixture screw.
Lovejoy
Put it all back together; it started second kick.
Felt slightly less "lumpy" warming up and smoother less boggy at pull away, but freezing here so could not give it anything on the road, found 300 yards of off road verge.
Second gear, stood up - PowerBand = wheelie, at little more controlable thought?! This is gonna be fun!
Anyone any thoughts on those jets - are they stock?
Thanks
Thanks
Looks fat for a 220... but I don't own a 220. Fat is good for a tame ride.
- sped66
My 220 has the same jets, though my entire exhaust is aftermarket. I get a moist residue at the muffler tip after a long ride, but no spooge. Roughly 1000' to 1500' elevation on average.
I suppose with your stock exhaust pipe there's a chance you could be a little rich. But I'm no jetting expert.
In the stable: '00 KDX220R, '02 XR250R
Gone but not forgotten: '80 XR80, '87 XR200R, '94 KDX250, '01 YZ426F, '86 XR220R
