Going Tubliss!
Has thanked: 27 times
Been thanked: 31 times
Going Tubliss!
Yep, I have decided to give the Tubliss setup a go. Got them at my local Cycle Gear with one of their $20 off coupons. Under $195 with tax. Plan to use them with Maxxis SI up front and an IT out back. I'll post up my experiences, riding and installing, hopefully soon.
BTW, for those that are running them, and tips or tricks to installing them that are not in the paper/video instructions? Also, I heard mention of running sealant in the high pressure tube to keep from losing pressure so quick. Anybody try this?
BTW, a cheap pic of them at home!
Mr. Wibbens
Post by Mr. Wibbens »
I'm gonna try them soon but I don't see much reason to do it on the front
Since I started riding bikes I've never had a flat front tire
I run some really low pressure up front currently (7lbs) so I know I have a good risk of getting a flat. Unfortunately, I ride by myself most of the time and don't want to get caught out in the middle of nowhere, at O'dark 30, or when it is 110 degrees out, trying to patch a tube. The Tubliss, hopefully, will provide me with peace of mind in those situations!
Mr. Wibbens
Wow, I can't imagine riding that low a pressure up front :shock:
My bike is scary below 13 psi on the front
Yeah, it is more scary with higher pressures! I currently have a Bridgestone M23 up front that was installed by the previous owner. It absolutely sucks for desert riding. It will wash out with no warning. Thankfully new tires are only a week or so away!
Woohoo! New tires should be here today! Maxxis SI front and a Maxxis IT rear. Man, I can't wait! Should have it all mounted up before this weekend! :supz:
jth
Post by jth »
“tips or tricks to installing them that are not in the paper/video instructions?”
Really clean the rim good, especially where the tire bead slides up and sits. Also, use lots of lubrication on the high psi tube and tire bead. I used very soapy water.
“running sealant in the high pressure tube to keep from losing pressure so quick”
Never tried it. Mine doesn’t leak down vary fast at all. Sealant in the tire (low psi side) = a big YES.
I ran this setup all last year with a Trials tire At 6 psi. No problems. I love it.
NewMexico505
Post by NewMexico505 »
SS109 wrote:I run some really low pressure up front currently (7lbs) so I know I have a good risk of getting a flat.
I run 8 or less psi in the front. AZ and NM both have lots of sand. Any psi higher and the front end washes out a lot in that sand.
Mr. Wibbens
Must run a stiff sidewall
If I run anything less than 12 the tire will roll over on itself under hard braking in tight turns, and pitch my ass on the high side
sped66
Post by sped66 »
SS109: Update? I'm interested in your toughts on the Tubliss setup!
In the stable: '00 KDX220R, '02 XR250R
Gone but not forgotten: '80 XR80, '87 XR200R, '94 KDX250, '01 YZ426F, '86 XR220R
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
I never understood patching a tube in the field... I have run both tires completely flat back to the truck several times.
Once I had a back flat and that was the fastest I have ever run a hare scramble track... hookup was incredible. I didn't know it was flat... all I knew is that I was hooking up!
Mr. Wibbens
Must be some stiff assed side walls
I've only had one flat. We were 22 miles out and 110 miles from our destination. I was not going anywhere until we put in a new tube
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
S12....
I apologize as I haven't been using them. I pinched the rear sealing tube and just haven't ordered a replacement. I have been busy with too many different projects and I lose track of things. I do plan on installing them at my next tire change which will hopefully be later this month or early January.
I can tell you that having to order a replacement from the manufacturer instead of being able to pick one up at a local shop bites.
scheckaet
Post by scheckaet »
how do you like your rear S12 Inda?
I like the front one, this is my second set, the 1st one lasted 2 seasons
The rear must be the worst tire I've ever had, I only have 5 rides on it and it's absolutely fubar, 1/2 the knobs are gone :evil:
I dunno why it chunked so bad, must be very very soft compound and only good for sand and mud. It's not like we have very much rock filed where I ride it's more like crop field, hard pack, roots and sandy section. Really pissed off, i'm guessing 2 more rides and it will be done. :evil:
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
It must be pretty good... harder compound being an "S"... lasting a long time when I want it to wear out. Wanting to go to a Trials tire...
Hooks up really good... lasts...
