Top End:Crank Service interval
gregp
Post by gregp »
Some of these recent threads have me thinking - How often do you guys replace your top ends? And, how many top ends do you normally go through before you address the connecting rod or crank bearings?
I know that our KDX's have very stout engines, and they seem to require much less service, both in terms of top end and crank services, than most other higher strung 2 strokes of similar displacements. This is one of the reasons that I love them!
I would guess that the toughest part of this question is that the "motor time" would only ba an approximation for most of us, and bike use varies so much from one person to another. I ride my bike about 2-3 hours a week, but I ride it pretty hard. Given that kind of service, I would expect to do a top end every year (whether it needs it or not! LOL!), and a crank service every 3-4 years. Am I way off?
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
kdxmaniac
Post by kdxmaniac »
i put a new piston in my bike about every 6 years!!!!!! i do a top end when my compression get to 155-160 psi.
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
That's about right.... :wink:
Been thanked: 17 times
An hourmeter is a great way to keep track of major maintenance without any wondering if you're past due. I got one of the hardline meters for $35. Trans oil and spark plugs every 10hrs, bearings every 50, top end every 100.
Totally depends on how you ride, for example in the winter months when it's snocross, you can have the engine wide open revved all the way out for 4-6 minutes at a time. (You should see the carb ice up!) but in th summer on the trails you'll be lugging it alot more.
Just a thought.
gregp
Post by gregp »
I guess that I am way off in my estimates... My '04 is still on its original top end and crank, though (as far as I can tell), and I have only owned the bike for 10 months or so... It would probably be a safe approach to replace the top end and service the crank now...
ihatefalling
Post by ihatefalling »
What do you guys mean by "service the crank"?
2005 KDX 220
R&B Carb Mod
R&B Head Mod
Fork Swap - 99 KX125 Valved for B woods plush
FMF Gnarley
Airbox Mod
Tagged
gregp
Post by gregp »
Service the crank = Replace the connecting rod, lower end needle bearing, and pin. It also should include main bearings and seals.
ihatefalling
That's what I was afraid you would say.....
You have to split the case to do that right???
2005 KDX 220
R&B Carb Mod
R&B Head Mod
FMF Gnarley
Airbox Mod
Tagged
Mr. Wibbens
Post by Mr. Wibbens »
I see no need to service the crank unless it is out of spec
KarlP
Post by KarlP »
Yup
I'm on year three with my top end. I've got about 350 hours on it, conservatively. I ride mostly single track and push it pretty hard.
Only twice in 36 years of bike ownership have I opted to go into the bottom end of a 2 stroke. On the first occasion it turned out to be a waste of money because of the condition of the rest of the bike. The second was the hybrid I'm on now. I had that job done by shop I trust completely. I'm pretty sure that by the time I wear out this lower end the rest of the bike will be junk as well. I'll be putting a top end in it this winter. I don't expect to be owning the bike for more than another year, though.
'08 KTM200xc
KX100 for the boy
