boyesen bowl??
Questions and Answers about the best carb and Head mods available for the KDX.
kdxmaniac
boyesen bowl??
Post by kdxmaniac »
has anyone ran....or run one of the boyesen super bowls? i was wondering if they work, or worth the money??
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
fuzzy
Post by fuzzy »
If you have fuel starvation problems due to extreme G-loading (fuel slosh) they help a lot. More prevalent on a vehicle that doesn't lean against the forces like a bike does...IE Shifter kart. I've seen guys do OK with these on a kart, but most will run a pump-around since they have to run a fuel pump anyway....Gets rid of the float, and pumps fuel in AND out of carb keeping it full all the time. On a bike, seen plenty of the baddest mofo's on some bad bikes running stock bowls. That being said I've never experienced a foam starve/g-load stave on a bike. :lol:
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
kdxmaniac
Post by kdxmaniac »
what about a reed spacer? does it help with low end? not worth the money?
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
fuzzy
Post by fuzzy »
It can be hit or miss depending on the motor. I'm not sure of the KDX. Most will just go to the DFIII Reed cage which is proven to work very well for increasing low-end with adding top-end performance as well. Lengthening the intake tract can in fact add low end, but it's at the sacrifice of top-end generally. Same as adding an exhaust spacer. Most of a power shift than a gain. A low-end pipe and DFIII are probably #1/2 on the list for low-end enhancement. Carb mods, head and/or porting would be next depending on how much you are trying to really get all the power off idle you can.
