Fuel & oil Ratios for diiferent Two strokes you have
gtoron
Post by gtoron »
This is not a KDX question but was wondering everyones thoughts.
I have four different types of lawn/garden tools that uses 32:1, 40:1 & 50:1
pre mix ratios. Echo weed wacker & Chainsaw,Lawnboy mower, Craftsman Blower.
Was wondering if I could use one pre-mix across the board for all these different tools as it would be a lot easier that mixing for each machine.
I currently run Mobile 2stroke synth oil or Amsoil Interceptor.
David_L6
Post by David_L6 »
I have an Echo weed trimmer, a chainsaw, and three 2 stroke motorcycles. I use the same gas in all of them: AV gas + Klotz oil @ 32:1.
Tedh98
Post by Tedh98 »
32:1 in all my 2 stroke engines, doesn't matter what they are in.
Has thanked: 9 times
Been thanked: 17 times
Agreed. run them all at 32:1 on whatever oil you like to use.
KarlP
Post by KarlP »
My saw and trimmer run much better on the motorcycle mix than they did on the cheap crap.
I was visiting my Dad and he had run out of his cheap crap so we ran some of my matorcycle mix in his saw. Much better...
'08 KTM200xc
KX100 for the boy
gregp
Post by gregp »
Your smaller bore, higher revving engines will require more oil than your larger bore machines. 32:1 should suit all of them. Chain saws are notorious for siezing with fuel/oil mixtures leaner than that.
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
Montips
Oil/ Gas Ratio
Post by Montips »
I've been running Golden Spectro @ 50:1 for everything two stroke since the early 70's with zero problems.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
50:1 Amsoil Interceptor in EVERYTHING! Even my 4 stroke mower... everything likes it.... :wink:
Little Jeff
Post by Little Jeff »
40:1 with Mobil 1 synthetic premix if you can find it.
Little Jeff
Riding with your buddies and an adventure, riding with certain individuals is an ordeal.
i been running the interceptor lately too. Been really happy with it. I mix 40:1 though.
Griffbones
Post by Griffbones »
Been using Amsoil Dominator @ 40:1 for a few years now, seems to work well for me.
'83 CR60R Fully restored
'97 DR350 (407cc)
2005 KX85 (103.5cc)
2006 KDX 200 (Bone stock other than Jetting, Gnarley woods, Turbine Core II)
2007 250 XC-W (SX head)
lemmy
Post by lemmy »
I run 44:1 in the KDX. The Echo blower and Echo weedeater call for 64:1. The Lawnboy lawnmower is 32:1.
I have noticed many people run less oil (the KDX spec is 32:1, but many run 50:1). How do you know how low you can go? I would like to just make 50:1 and run that in the Echo stuff and the KDX and just keep the lawnboy on 32:1 cheap lawnboy oil (it has been running great for 10 years on that and it is cheap).
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
When these things came out... there was no high quality synthetic oil. Now that it is available... the oil manufacturers started out calling for 100:1
People weren't comfortable with that... so they started suggesting 50:1 ... people could almost buy that ratio.
Lawnboy and other 2 stroke lawn motor manufacturers don't think that you are going to run high quality synthetic so that's why they suggest such heavy oil concentrations.
Mr. Wibbens
Post by Mr. Wibbens »
Indawoods wrote:50:1 Amsoil Interceptor in EVERYTHING! Even my 4 stroke mower... everything likes it.... :wink:
Me too, cept mine has 5% Toluene
