Hi all.
Just needed some input with regards to the odometer. Recently replaced the front tire put back together no problem and odometer worked. Took bike out this weekend put on about 10m and then noticed odometer was no longer working. Did go through some (shallow) water but no thick mud. Unit up top is still working (pull/push lever, change numbers, etc) so I'm thinking the bottom piece or cable.
Just wondering if there is a common problem I can look for before dis-assemble wheel, etc or is it shot?
Searched, but could not find anyone that has noted a problem/fix.
Any input is greatly appreciated
Ditton
odometer not working
- Mr. Wibbens
Unscrew cable from meter and turn tire, cable should turn
If it does not, take cable off and check to see if end has broke off. Mine usually breaks about 2" from the end
Or if you are lucky you bent the tabs on the meter drive when you installed wheel. Just need to take it apart and straighten
- Mr. Wibbens
at the wheel. I think it gets moisture and corroded
- KDX4ID
The speedo cable is a maintenance item and should be lubed occasionally
CURRENT FLEET
2008 KTM 990 Adventure...Alaska here I come!
2010 KTM 300 XCW... stop me before I buy again!
2005 KDX220... single track sweetie
2007 KTM 450 EXC... my baby
2008 KTM Superduke... Canyon Carver
1996 Honda 650L... GONE but not forgotten
http://www.friendsoftruckeetrails.org
- Mr. Wibbens
Ya think?
- KDX4ID
Yes. it's true. Also, the KDX requires g-a-s-o-l-i-n-e in the fuel tank to go.Mr. Wibbens wrote:Ya think?
Not to mention a-i-r in the tires.
Complicated stuff for sure... well worth it in the long run
CURRENT FLEET
