Howling noise?
rbates9
Howling noise?
Post by rbates9 »
I have had a howling noise coming from the front of the bike. It has done it since I got the bike, no change from jetting, repacking, or gas mix. It only seems to do it during acceleration from about half to about full throttle? Any body else have this happen? I have boysen reeds fmf woods pipe turbin core 2 and the air box lid cut open. It will not do it sitting still and it has about 145 to 150psi compression. Any thoughts?
Mr. Wibbens
Post by Mr. Wibbens »
clutch
rbates9
Post by rbates9 »
I'll bite, what about the clutch? the noise seems to be coming from the pipe. I have had the pipe off and cleaned it, it wasn't that bad but it was off. I also looked into the cylinder and it looked good on the back side and the piston looked good on the front side. I have done several compression test and they all were around 145 to 150 over the summer. :? I'm not ruling any thing out but the clutch is working good, good feel and engages good with no slippage.
JoKDX220r
Post by JoKDX220r »
when you pull the clutch did the noise change ??
rbates9
Post by rbates9 »
You can only hear it under a load and during acceleration.
scheckaet
Post by scheckaet »
kips or water pump bearing?
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Big end bearing...?
rbates9
Post by rbates9 »
Sounds like it might be time to take something apart. :sad:
Mr. Wibbens
sounds like a clutch
rbates9
Post by rbates9 »
What about the clutch??? Sliping? Draging? Two dead hampster's in it?
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
I say.... 3.
Mr. Wibbens
More likely a slipping clutch howling than it coming from your pipe, unless of course that is where the hamsters are located
rbates9
Post by rbates9 »
Maybe it could use a new clutch. Thanks
Mr. Wibbens
or different oil...
bigerestblazer
Post by bigerestblazer »
ive had a connecting rod bearing make a howling sound between 1500 and 2500 rpms. swapped that out and it went away. not on a kdx but just a suggestion.
Sometimes in life when it seems like things aint goin your way theres always one answer...BIGGER HAMMER
rbates9
Post by rbates9 »
I have tried a few different oils and didn't notice a difference. What do the rest of you use for brands and wt.
Mr. Wibbens
If it does it all the time it's probably a bearing
Usually, on my bike it will only howl while accelerating when the motor is fairly cold
But if you had an oil that's energy conserving it might do that
JoKDX220r
Post by JoKDX220r »
if you want you can try to take a long screwdriver, put it on the case and try to hear where the noise is come from...
you can also try with this : http://www.diseno-art.com/images_2/mech ... oscope.jpg
Mr. Wibbens
under $10 at HF
KarlP
Post by KarlP »
I'm trying to picture using a stethoscope under these conditions.
Thanks for the opportunity to offer a usefull comment :lol:
'08 KTM200xc
KX100 for the boy
