Troubleshooting tips
frankenschwinn
Post by frankenschwinn »
First real issue I have had with the KDX.
I rode in Colorado and Moab, UT. The bike was running like a scalded dog
Rode it yesterday and it was running great.
Went to go for a ride today and the bike would not start. seemed to be getting fuel. When I checked spark it seemed a little weak.
I have a lot of hours on the top end so kind of worried about that too.
Looking for troubleshooting tips
2002 kdx 200
stock motor
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Did ya try bump starting it? Filter Clean? Crap in the bowl? Reeds OK?
frankenschwinn
Indawoods wrote:Did ya try bump starting it? Filter Clean? Crap in the bowl? Reeds OK?
Did try to bump start. no luck
brand new filter
Bowl was clean
did not check reeds as they are pretty new but I will pull them and take a look.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Change the plug? Take the plug out of the silencer? :mrgreen:
frankenschwinn
Indawoods wrote:Change the plug? Take the plug out of the silencer? :mrgreen:
Check and check...
I have had the silencer plug bite me before
gregp
Post by gregp »
Disconnect your kill switch, and look for pinched wires up around the steering neck. IIRC, the spark on these bikes normally looks weak, though.
The motor needs 3 things to run: proper mixture, properly timed spark, and compression.
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
rbates9
Post by rbates9 »
I hate to bring it up but was it running good or exceptionally good? My unfortunate experience in the past with other bikes and quads is they run the best just before they die. :cry: Did you check the compression?
frankenschwinn
rbates9 wrote:I hate to bring it up but was it running good or exceptionally good? My unfortunate experience in the past with other bikes and quads is they run the best just before they die. :cry: Did you check the compression?
It was running very good. I had to jet it when I went to CO. I had it pretty lean. 142/38. I re-jetted when I returned to OK. it is currently at 155/42.
I put a readyfilter brand air filter on it. between the last ride and the time it would not start. gonna pull that and see what happens
Mr. Wibbens
Post by Mr. Wibbens »
water in your gas?
KDX4ID
Post by KDX4ID »
Kill switch
CURRENT FLEET
2008 KTM 990 Adventure...Alaska here I come!
2010 KTM 300 XCW... stop me before I buy again!
2005 KDX220... single track sweetie
2007 KTM 450 EXC... my baby
2008 KTM Superduke... Canyon Carver
1996 Honda 650L... GONE but not forgotten
http://www.friendsoftruckeetrails.org
MontanaKDX
Post by MontanaKDX »
I have had two bikes suffer from a bad kill switch. The same symptoms that you describe. One of them had a weak spark, the other had an occasional spark. I disconnected the kill switch and they fired right up.
It's worth a try.
'97 KDX 220
RIDE ON!
