My thread (2000 KDX 200 rebuild)
canuckhybrid125
Post by canuckhybrid125 »
Did they plug and tape off all the holes where bolts go before powdercoating your frame and swingarm?
It Is What It Is
2000 KX KDX Hybrid
2006 KX 100
2004 TTR 125 LE
2010 KTM 300
bmiller
Post by bmiller »
canuckhybrid125 wrote:Did they plug and tape off all the holes where bolts go before powdercoating your frame and swingarm?
yep. threads, bearing seats, speed clip holder thingy,...
canuckhybrid125
bmiller wrote:>|<>QBB<
Good they missed 2or3 on mine and I had to retap.
It Is What It Is
2000 KX KDX Hybrid
2006 KX 100
2004 TTR 125 LE
2010 KTM 300
bmiller
Update:
Post by bmiller »
OEM parts have arrived. A little scary...
See wiki for updated pictures.
http://www.phospher.com/index.php/2000_KDX_200
heckler
Post by heckler »
nice paint job! Looks great.
Is the KX500 stem the same as the KDX? Does it look like a straight swap as expected?
bmiller
Post by bmiller »
It appears the KX500 stem is exactly the same. I'll be pressing bearings on and off this weekend. I'll take pictures and report my progress.
bmiller
Post by bmiller »
Update: Installed a bunch of bearings/races, seals, triple clamps and greased up.
bigerestblazer
Post by bigerestblazer »
looking great and i Love the special tool!! lol i have about 20 different sizes of those laying around just because i had to make a bearing go in and dont have a driver kit. keep up the good work your on the downhill slide now it looks like.
Sometimes in life when it seems like things aint goin your way theres always one answer...BIGGER HAMMER
David_L6
Post by David_L6 »
Good job.
Thanks for taking the time to take and post all the pictures. They will be a lot of help to those of us that do in the future what you are doing now.
bmiller
Post by bmiller »
So far so good. I'm having a great time doing it. The press has really made things so much easier.
When I'm "done" I'll post everything that's on my wiki in this thread to hopefully create more keywords for others searching with questions that I may have answered.
I hope the KDX is as fun as I remembered in 2005 :)
heckler
Post by heckler »
yeah, that lower shock bearing is a pain in the butt. I had our machinist make a tool for me to press it out with.
bmiller
Post by bmiller »
Got my top-end back from Eric Gorr. I just hope he'll refund money.
The worst job I've ever seen...
scheckaet
Post by scheckaet »
u sure u got YOUR cylinder back?
:shock:
bmiller
Post by bmiller »
scheckaet wrote:u sure u got YOUR cylinder back?
:shock:
I am 100% positive it's not the one I sent him.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Another case of he got too big for his britches....
Coop
Post by Coop »
Sounds to me like you got a cylinder someone sent in for repair sent to you by mistake. I've talked with Eric quite a bit in the past and I would really be surprised if that was intentionally sent to you that way.
bmiller
Post by bmiller »
Coop wrote:Sounds to me like you got a cylinder someone sent in for repair sent to you by mistake. I've talked with Eric quite a bit in the past and I would really be surprised if that was intentionally sent to you that way.
I'll give him a call on Monday. It is bored to 225cc which is what I requested. Do you guys think a head gasket will seal that pitted deck?
Tomm9050
Post by Tomm9050 »
Try RB designs / great work on my head.
http://www.rb-designs.com/
1992 KDX 200; RB head; Fatty pipe; stock carb; Stock silencer
40 / 150 / CGK pos 3
bmiller
Post by bmiller »
Tomm9050 wrote:Try RB designs / great work on my head.
I was considering sending my carb to RB for their famous modification. The machine work done by Eric looks legit. I'll post an update after I talk to him.
bmiller
Post by bmiller »
I just got off of the phone with Eric.
He seemed real nonchalant about the condition of the cylinder. He said the pitting is normal after an acid wash and he recommends just using a little sealant. He also said Kawasaki's material is '****' which is why he always helicoils the threads. He missed a few threads which were damaged and I'll have to do them myself.
He also said the damaged/stripped cylinder plugs where like that when he got it and he had a hard time removing them.
Also, he did send me a different cylinder. My cylinder had a sleeve installed and couldn't be bored to 225. So,... it explains a lot.
I'm not sure how I feel about the whole situation.
Is 225cc worth the pitting and helicoils? I'm feeling it is,.. what do you guys think?
