Replacing Leaky Seal
KDX4ID
Post by KDX4ID »
No wonder I can't get the darn thing jetted correctly.
Is it possible to replace this seal with out splitting the cases?
It doesn't look like it to me but.....
CURRENT FLEET
2008 KTM 990 Adventure...Alaska here I come!
2010 KTM 300 XCW... stop me before I buy again!
2005 KDX220... single track sweetie
2007 KTM 450 EXC... my baby
2008 KTM Superduke... Canyon Carver
1996 Honda 650L... GONE but not forgotten
http://www.friendsoftruckeetrails.org
Tedh98
Been thanked: 2 times
Post by Tedh98 »
Gotta split the cases . . .
Been thanked: 19 times
Yup gotta split them. How bad is it leaking?
KDX4ID
Post by KDX4ID »
The amount in the photo is about 800 milles of leaking.
CURRENT FLEET
kevfort19
Post by kevfort19 »
the mine have two years and it leak about 10 ml for a complete summer
KDX 220 2001 =)
Don'T drink and drive...just give some gas and fly :D
Griffbones
Post by Griffbones »
Anytime the stator side leaks, you risk is also sucking in air and leaning out the engine to a dangerous level. IMHO
'83 CR60R Fully restored
'97 DR350 (407cc)
2005 KX85 (103.5cc)
2006 KDX 200 (Bone stock other than Jetting, Gnarley woods, Turbine Core II)
2007 250 XC-W (SX head)
kevfort19
Post by kevfort19 »
the stator is seal by a gasket so normally it don't suck air or dust...
KDX 220 2001 =)
Griffbones
kevfort19 wrote:the stator is seal by a gasket so normally it don't suck air or dust...
I am sorry but I have to call BS on that one!
The stator cavity is not completely sealed off from atmosphere on most engines. Ever see a two stroke scream into the high RPM's due to a bad left side crank seal? I have. :wink:
'97 DR350 (407cc)
2005 KX85 (103.5cc)
Has thanked: 15 times
Been thanked: 28 times
Griffbones wrote:>|<>QBB<
Yep, I seen it too. It WILL suck air through that seal.
Griffbones
Most engines have a drain hole in the cases or a spot on the bottom of the cover that allows for moisture to drain out. This does allow for air and dirt to be sucked in through a bad crank seal, this also causes main bearing failures too.
'97 DR350 (407cc)
2005 KX85 (103.5cc)
kevfort19
Post by kevfort19 »
it's good to know ;)
KDX 220 2001 =)
kevfort19
Post by kevfort19 »
is it better to put aftermarket seal or OEM seal for the crank??
KDX 220 2001 =)
