airbox lid removed?
heckler
airbox lid removed?
So, the bike (05 KDX220) I just bought had the airbox lid removed and the box and filter were full of dust. Buddy gave me the lid, I assume he removed it for better airflow.
I did think this bike ran much better than my last 220, but that could be for a myriad of reasons.
The engineer in me thinks opening the box wide open to dirt and water is a bad thing, so I reinstalled it.
Opinions? Experiences? Thanks!
- Mr. Wibbens
There's other options to get the same result
- scheckaet
if you keep your air filter clean, shouldn't be an issue, unless you like to use your bike as a submarine
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- ss109
- Has thanked: 34 times
- Been thanked: 59 times
I run mine without the lid and no problems so far. Of course, I live in the desert so there are not a whole lot of opportunities to drown my bike.
Remember, dirt in the air box is not a problem. Dirt past your air cleaner is.
- Been thanked: 19 times
cornishwrecker220
my 03 220 never really liked the airbox lid removed (even after i re-jetted it ripped on wide open throttle but i lost some of the bottom end grunt)...instead i just removed the snorkle & leaned off the jetting now it pulls strong in every gear, & sounds much better too..i cut the foot off a pair of the girlfriends old tights & slip that over the air filter in dusty or muddy conditions, then remove it when it gets a dirty...the air filter remains clean & wont need cleaning for several more rides. .helpful tip!
Jayhawk Ken
- OLHILLBILLY
I've never used the airbox lid on mine, no problems yet (almost 2 years). Looks to me like if your riding in dusty enough conditions to get a layer in the airbox, it would do it with the lid or without. Same for getting water in the motor. Submerge it with the motor running, and it's going to fill it with water even with the lid on it.
Just keep the filter cleaned, and it'll all be good.
2004 KDX 200.. Coupla mods
2009 KX250F.. Track Star
2007 Hayabusa.. Street Madness
- Griffbones
Personally I didn't notice much of a power increase on our stock KDX when removing the air box lid. This was tested when I was jetting the bike and trying different combinations. This is not too say that it didn't add some power, but on a stock bike with only a pipe and silencer change it wasn't dramatic.
As far as reliability, I wouldn't worry about it, most MX bikes come from the factory with an open airbox. As mentioned, keep the filter clean and well oiled and you will be fine with the lid removed. As far as water goes, this would mean you were seat deep in water, right? I think at that point you are awful close to filling the exhaust with water too, so what's the difference.
My .02 worth
My .02 worth
'83 CR60R Fully restored
'97 DR350 (407cc)
2005 KX85 (103.5cc)
2006 KDX 200 (Bone stock other than Jetting, Gnarley woods, Turbine Core II)
2007 250 XC-W (SX head)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
mtnickel
I second this. If you do the calculations of the flow area of the snorkle. It's easily 20%+ bigger than the flow area of the Throttle body. I added 2 more 1" "snorkels" with PVC elbows (function exactly like stock snorkle) just for peace of mind.Personally I didn't notice much of a power increase on our stock KDX when removing the air box lid. This was tested when I was jetting the bike and trying different combinations. This is not too say that it didn't add some power, but on a stock bike with only a pipe and silencer change it wasn't dramatic.
My .02 worth
I think the perceived power increase is the same reason why 95HP honda owners think the intake made their rides faster...it adds a fair bit of sound/throatyness to the motor.
My additional .02 worth :)
- OLHILLBILLY
Main (only) thing I miss the airbox lid for.. it was a good place to mount the little rectifier thing.
Got it screwed to the inside of the box now, but it's a PITA having to take it off to change the air filter.
Need to look for another place to put it I guess.
- Griffbones
- OLHILLBILLY
- Varmint
