I have cleaned carb and checked float level. All seems fine. My problem is that turning the screw in or out has NO effect on idle what so ever. I further removed it while engine running and thought I could feel a slight vacumm with my finger over it, but plugging it with finger still has no effect?
What gives???
stock carb 152/48 in top clip
carb idle screw...turning does not effect idle?
01twostrokingfun
- scheckaet
this might help
http://www.kdxrider.net/forums/viewtopic.php?t=1156
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
01twostrokingfun
You can't just turn the screw... it doesn't work that way...
You have to turn the throttle... adjust the screw and let the slide settle on the screw. Or else it will just damage the screw....
01twostrokingfun
- scheckaet
plugged up circuit somewhere maybe?
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
