need some pointers
GreatWhiteHunter
need some pointers
I have a couple q's that I'm sure have already been answered but I can't seem to find the right thread. If someone could point me in the right direction, I would really appreciate it.
I'm a little big & tall for the KDX and need to stiffen and raise the handlebars. I'm currently using Rox 2" risers in the stock clamps and that is a VERY poor solution. It's high enough but just about every time I hit the ground (and that's quite a bit actually) the bars end up tweaked. The stock clamps are impossible to line up correctly with these risers and any weird torque angles has these things out of whack in no time.
What I think I need to do is stiffen/remove the rubber bushings in the upper triple clamp and put on a fixed riser for my bars. I'm thinking an upper triple clamp swap would do the trick, I just don't know what will fit.
Thanks in advance!
Thanks in advance!
Solid cones help... remove the rubber ones and install the solid aluminum cones. Your on the right track... Check Scotts site and see what they have to offer....
cornishwrecker220
i used to have a similar problem on my 220...like you i too am tall so i fitted higher bars & also rotated the bar mount 180 degrees which moved them forward slightly & also raised then a tad..but when you drop the motorcycle the bar clamps would shift thus making them out of true...what i did was make up a alumimimum brace & mount this to the top of the bar clamp bolting it down useing the 4 bolts for the bars...its a cheap solution & seems to cure the bars from twisting in the event of a spill & you can still benifit from having the damping from the rubber mounts too!.
gregp
Similar to Cornish, I made an aluminum plate that bolts right on top of my bar clamps, using all 4 bolts. It helps a lot, but I would still like to get solid cones. Does anybody know where to buy solid cones?
Maybe I will have to make my own....
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
GreatWhiteHunter
I had no idea there was a replacement for the rubber to make them solid I was only hoping. That's good news.Indawoods wrote:Solid cones help... remove the rubber ones and install the solid aluminum cones. Your on the right track... Check Scotts site and see what they have to offer....
Since I'm a n00b, can you tell me who Scott is and how I would find his site?
Thanks in advance!
heckler
- David_L6
jbowens2401
GreatWhiteHunter
