Jet question
Questions and Answers about the best carb and Head mods available for the KDX.
racc
Jet question
Post by racc »
On a keihin PE carb from a 1990 kdx 200, The bit that the main jet fits into has a lock nut, should it be screwed down and locked or should it be set at a height and locked, if is set where should it be set to?
Thanks
Steve
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
A PE is the wrong carb for a 90 KDX... it should be a PWK.
racc
Post by racc »
I have it running just about right, but wasn't sure about the bit the main jet sits in
RBD
Post by RBD »
On a PE carb, the part that the main jet fits into is suppose to be tightened up snug and then you tighten up the jam nut.
Ron
racc
Post by racc »
Thanks
