I received and installed my V-Force reed cage last night. I noticed that the cage has a small tap on the top which only serves to carry the V-Force logo. This tab interfered with the cylinder casting, and would not alow the cage to seat tightly unless I trimmed a portion of the tab off with a dremel or some other means. I looked at the reed cage, and it appeared completely symetrical, so I just flipped it over and placed that logo tab at the bottom. My bike ('04 KDX200) runs much stronger now.
I was just curious if others had encountered this "tab" issue.
Thanks!
V-Force cage installation
- Griffbones
I have not installed a V-Force on a KDX, but on my KTM and my sons KX 100 the logo was located on the side of the reed cage not on the top. I am not sure if it can be turned that way on a KDX.
'83 CR60R Fully restored
'97 DR350 (407cc)
2005 KX85 (103.5cc)
2006 KDX 200 (Bone stock other than Jetting, Gnarley woods, Turbine Core II)
2007 250 XC-W (SX head)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
Mr. Wibbens had an issue with his version 2 on his.....
gregp
The logo tab definately can only go on the top or the bottom on this model. I thought that I had read somewhere on a forum that it was important *not* to mount it upside down, but, looking at it closely, it appears completely symetrical so I could see no reason not to do so, other than the pretty little purple logo can not be seen at all from the bottom.
If someone were to give me a reason that I should remove it, grind off the tab, and re-install it, I would surely do so.
I will re-read the instructions again to make sure that there is no definitive top and bottom. The cage is not marked as such.
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
gregp
- Griffbones
I don't think there could be a difference top to bottom.
I wonder why they put the logo on top instead of on the side as they do for other models?
'97 DR350 (407cc)
2005 KX85 (103.5cc)
'97 DR350 (407cc)
2005 KX85 (103.5cc)
Ah.... they work fine....
