freezing pipe to remove dents????
wvsp612
While surfing some other sites, KTMTALK.COM specifically, I saw several threads about putting water in the pipe and freezing the pipe to remove dents. Anyone have any experience with this? If so, does it work?
Cody
2003 KDX 200
2003 KDX 200
Kyle651
wvsp612
You run a chance of spliting the pipe too.... not sure if it would work or not.
- ihatefalling
kevfort19
it have a better technique ... you weld two caps to the two holes of the pipe . you take a torch and you heat it.
the only thing is that the chrome or nickel plating change color but your pipe have no dents. normally this technique is use for the stock black pipe
KDX 220 2001 =)
Don'T drink and drive...just give some gas and fly :D
- TWMOODY
I did it on a crushed titanium pipe on my 450 and it worked great.
It took three freezes to remove the dent in pipe with about a
50% restriction.
After the freeze you could hardly tell it was ever damaged.
I did not plug the ends.
I would be careful on a 2t pipe not to separate at the seams.
Check it a couple hours after you put it in the freezer then every
hour after.
50% restriction.
hour after.
jbowens2401
I have used the freezing technique successfully, but it was on a four stroke pipe. I put shrink wrap over both ends and taped it water tight. My water level in the pipe was as high as I could get it. I didn't ever think about it busting but that a good point. I would probably be more prone to bust on a two stroke pipe b/c they have seams and seem to be thinner that the four stroke pipe.
Thanks,
John
Thanks,
John
- kdxmaniac
i do the 2 stroke pipes with no problem... useing the heating process that is. i have tryed the freezing with NO succes.... also useing the freezing process you risk splitting the pipe on the seems, there is no way to pinpoint you problem areas.. ........................ i use about 50 psi and a torch to do pipes. as far as a bomb?? the pipe, if, and i say if the pipe "blows" up.. it would just spit the weekest place and the air would just spray out..... think about it this way.. you have 35psi to 85psi in a rubber tire,,, right? when you have a blowout, it is the weekest point, and it dosent blow the car up now does it??
- kdxmaniac
i guess you could? but it takes like 15-20 min to fix with heat, and a long time to freeze and you dont know what you will end up with, if it even works............. and think about ice "pressure"...... when a car block freezes, i have seen the freeze plugs rusted so that they did not work, and the block split open like a tin can, that is alot of force. i can controll the heat, and work a body hammer to what i need, where i need it...... you cant control the amont of pressure with ice..
- TWMOODY
kdxmaniac wrote:i guess you could? but it takes like 15-20 min to fix with heat, and a long time to freeze and you dont know what you will end up with, if it even works............. and think about ice "pressure"...... when a car block freezes, i have seen the freeze plugs rusted so that they did not work, and the block split open like a tin can, that is alot of force. i can controll the heat, and work a body hammer to what i need, where i need it...... you cant control the amont of pressure with ice..
You wouldn't have fixed my pipe with heat ! Guaranteed
Kyle651
I'm gonna try it with a shitty lt250 FMF expansion chamber (It's had holes welded shut before and looks like crap) just to test my idea.kdxmaniac wrote:i guess you could? but it takes like 15-20 min to fix with heat, and a long time to freeze and you dont know what you will end up with, if it even works............. and think about ice "pressure"...... when a car block freezes, i have seen the freeze plugs rusted so that they did not work, and the block split open like a tin can, that is alot of force. i can controll the heat, and work a body hammer to what i need, where i need it...... you cant control the amont of pressure with ice..
I'll let you all know.
It's an FMF fatty pipe.
pietman
- Been thanked: 17 times
Kyle651
Yeah, that's why I'm testing it on a pipe I don't use, and is already shittypietman wrote:Carefull with the freezing dent removal method. I know it has worked for some, but I wouldn't leave it in the freezer overnight. Check it often, as has been mentioned.
This is what happened to one of the posters on my local offroad forum after leaving his 4t pipe in a freezer too long:
pics removed
- kdxmaniac
- TWMOODY
