SR Pics!
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
The spirit of the post I believe since it was so long ago was that the parts would be next to impossible to source.
I recall that the tap looked differently on some of the Aussie bikes that have been posted on the forum before....
Been thanked: 19 times
Indawoods wrote:Well... if you have a Canadian model... then that's not a US model is it?
Wow... Either you must be joking, or you still don't understand what I'm asking.
I'm trying to find out if the spare port located on the left radiator is the one you're talking about that goes to the thermostat on the SR's. Check the part numbers, the US and Canadian radiators are the same. I think all north american KDX's were identical with the exception of the tripmeter being in miles or KM.
Hence, I ask why you would state that "US models don't have it" when clearly they do. Or, is there some confusion on the port in question?
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
I edited my post.... but... just because something has the same part number, doesn't make them the same.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
A thermostat on a KDX would be pointless IMO. The high output stator would not be though... that is the only thing I would want from a SR. Definately not the metal gas tank! :mrgreen:
Indawoods wrote:I edited my post.... but... just because something has the same part number, doesn't make them the same.
I thought that was the point of different part numbers. On a side note, I just checked the US parts fiche, and I can see the same port, plug, and washer present on the US fiche as on my Canadian bike.
A7 FWIW.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Like I said... I believe they are different from a SR what I recall.
Has thanked: 15 times
Been thanked: 28 times
I would like to have the oil injection, personally. I love that about my old 73. Variable mix by RPM and throttle position. Neat.
scheckaet
Post by scheckaet »
juliend wrote:I would like to have the oil injection, personally. I love that about my old 73. Variable mix by RPM and throttle position. Neat.
till it breaks down and you find out ... too late.
Been thanked: 56 times
scheckaet wrote:>|<>QBB<
Yep! The oil injection was one of the first things removed from my old RD's.
CNDN KDX
Post by CNDN KDX »
Inda, would be able to send the link for the last 250. I have a Canadian (obviously) modela dn the thought of motarding it has been fascinating me for a few years. Would love to chat with owner of last bike, if he could be tracked down. :supz:
rbates9
Post by rbates9 »
The port in the radiator could be for a temp sender but not a thermostat. A thermostat needs to be able to stop the flow of coolant, that could not be done once in the radiator.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
You are probably right... it probably wouldn't be that hard to adapt one either....
Denexc
Post by Denexc »
Not much in them to break down.
Run by a gear cog which gives pressure and throttle cable to adjust flow.
Re: SR Pics!
Holy old thread, Batman!
Sent from my HTC6435LVW using Tapatalk
