Time for a Top End Rebuild
ejweick
Post by ejweick »
What king of piston, rings, gaskets should I buy?
Where should I buy the stuff?
I have a stock '96 KDX200. I've been riding it a few times a year for he past four years. My wife and kids are now into trail riding so I've ridden it about a dozen times this year. I've noticed more smoke lately. This past Saturday it got very hot, melted the number plate on the right. The coolent level was about an inch below the low mark in the resivore. I flushed and replace the coolent. I also found the air filter to be damaged and quit a bit of powdered filter foam had made it way into the carb. I pulled the airbox, carb and reeds and cleaned everything, replaced the filter. After everthing was put back together, it fired on the second kick.
DL1000 V-Strom
CRF450R
KDX200
XR650L
EX500
XR200R
TTR125LE
RM 80
XR70
CRF50
JR50
Ford Expedition
Toyota Tundra Dbl Cab
scheckaet
Post by scheckaet »
rockymountain
wiesco is the most common for piston
I used tusk gasket top end kit, or moose...
I'd get a new filter if I were you and some good quality oil for the filter.
ejweick
Post by ejweick »
I put a UNI filter in it, with No-Toil spray filter oil. I'm itching to take it out and run it to see if its going to overheat again. My neighbors give me dirty looks when I ride it through the hood.
DL1000 V-Strom
CRF450R
KDX200
XR650L
EX500
XR200R
TTR125LE
RM 80
XR70
CRF50
JR50
Ford Expedition
Colorado Mike
Post by Colorado Mike »
Uni and No toil both claim that Uni filters will come apart in No Toil oil.
Mike
'04 KDX220
ejweick
Post by ejweick »
Are you serious? I let the Cycle Gear salesman guide me into this. I should have read the lable.
DL1000 V-Strom
CRF450R
KDX200
XR650L
EX500
XR200R
TTR125LE
RM 80
XR70
CRF50
JR50
Ford Expedition
Colorado Mike
They don't say how long it takes. I had a stock filter come apart from using too hot water. I glued it back together and it still works. You can buy No Toil pre-oiled filters from RM pretty cheap too.
Mike
'04 KDX220
ejweick
Post by ejweick »
I just emailed UNI and No-toil. I'll post their responses.
DL1000 V-Strom
CRF450R
KDX200
XR650L
EX500
XR200R
TTR125LE
RM 80
XR70
CRF50
JR50
Ford Expedition
scheckaet
Post by scheckaet »
I used uni and no toil, yes they do come apart.
HOWEVER, I found that by the time they did (mine lasted about a year which is as long as the oem one lasted), they were good to be replaced, the foam was getting brittle and turning into dust.
I used to throw it in the washing machine though and I'm sure that didn't help.
Now I soak them a few min in warm water with soap and repeat the process untill they are clean (2-3 times)
Just my 0.02
KarlP
Post by KarlP »
Why are you headed for a rebuild, though?
It may not be necessary.
Did you do a compression check? Does it run O.K.?
I'm just saying, these are pretty tough motors. I'm on year three with a 220 motor in a hybrid and I ride a LOT, couple of times a week and twice on weekends, 1.5 to 2 hours run-time each, so I've got probably 400 hours on the last rebuild (It might be time, now)
Just wondering....
'08 KTM200xc
KX100 for the boy
ejweick
Post by ejweick »
I'm not sure I do need a top end. I'm going to borow a compression tester this friday and check it. The bike runs pretty well. It smokes more than I think it should. That could be the cheap oil I use (whatever is on sale at wal Mart).
DL1000 V-Strom
CRF450R
KDX200
XR650L
EX500
XR200R
TTR125LE
RM 80
XR70
CRF50
JR50
Ford Expedition
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Usually if it starts getting hard to start or jet... then it is ready for a top end. Otherwise, if it is running good... I don't worry about it.
ejweick
Post by ejweick »
This is the reponse from UNI about the filter oil. Not too specific about the possible inplications of using No-Toil on the UNI filter.
To UNI:
Someone on the KDXrider.net told me that you shouldn't use No-toil on a UNI filter. Is this true? The manager at my local Cycle Gear sold me the stuff together along with the No-toil cleaner. Tell me the truth, before ruin my filter, or bike.
Eddie
Hi,
Do NOT use No – toil
Use Uni filter oil & cleaner for best results.
Cycle gear should have UNI in stock.
Thanks,
Tom
http://WWW.UNIFILTER.COM
DL1000 V-Strom
CRF450R
KDX200
XR650L
EX500
XR200R
TTR125LE
RM 80
XR70
CRF50
JR50
Ford Expedition
scheckaet
Post by scheckaet »
of course they're gonna tell you to use THEIR product. Financial gain and for liability reason...
ejweick
Post by ejweick »
That was a safe answer. What was conspicuously absent was any comments about the other product, good or bad.
DL1000 V-Strom
CRF450R
KDX200
XR650L
EX500
XR200R
TTR125LE
RM 80
XR70
CRF50
JR50
Ford Expedition
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
I don't think that they are going to get rich off your choice of filter oil. I wash mine by hand with Dawn and water and use Silkolene spray.... safe for all filters.
ejweick
Post by ejweick »
I'm waiting to hear what No-Toil has to say about the safety of their product on UNI filters.
DL1000 V-Strom
CRF450R
KDX200
XR650L
EX500
XR200R
TTR125LE
RM 80
XR70
CRF50
JR50
Ford Expedition
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
It's just a glue incompatibility.... not a big deal.
ejweick
Post by ejweick »
If you're saying the filter may come apart at the glued seams, that's not a big concern. I was worried that the foam was going to disintergrate and get sucked into the carb.[/img]
DL1000 V-Strom
CRF450R
KDX200
XR650L
EX500
XR200R
TTR125LE
RM 80
XR70
CRF50
JR50
Ford Expedition
Brian
Post by Brian »
No Toil is alcohol based. It's the alcohol that disolves the glue at the seams of air filters.
If you use the No Toil on a non approved filter, the faster it dries the less it softens the glue.
On my non approved filters, if I'm not installing them for use right away I wet them down and set them on a clean paper towel or newspaper in the sun or on the hood of my truck to dry.
Most of my filters are now the No Toil type so it's not too much of an issue.
Since it's alcohol based I just clean my filters in a small bucket of alcohol. They clean right up and dry very fast. I don't even have to wait for them to dry all the way before I re oil (with No Toil) them.
Colorado Mike
I just use the No Toil soap. Seems to work great and I can do it in the kitchen without stinking the place up.
Mike
'04 KDX220
