What sprocket set are you running ??
12/47
36
15%
12/48
9
4%
12/49
5
2%
12/50
4
2%
12/51
3
1%
13/47
61
26%
13/48
25
11%
13/49
32
14%
13/50
28
12%
13/51
7
3%
Other
18
8%
Who gives a rats, I just wanna ride...
8
3%
Total votes: 236
MX500
Post by MX500 »
14/47 for me. My bike is plated and I need the high gearing for the street.
tommorth
Post by tommorth »
13/46 with a 19 inch rear rim until today now 12/46 still with the 19 and from a quick squirt up and down the drive seems to have a lot more zap :grin:
beware the mighty kdx
220rider
Post by 220rider »
just put on 14/48 combo for desert and more open trail riding.
Then i go to 13/48 for tighter trail riding.
cycra probend handgaurds, wiesco piston, renthal chain, ims desert tank, pro taper SE bars.
WNC
Post by WNC »
Whaa,whaa,whaa,wha....I look down at my speedo as i just tapped into 4th and it says 29 mph !?![/quote]
Perhaps he was carrying his front wheel during all that whaa,whaa,whaa,wha.... ??
Anyhow, I run a 13/49 in mostly single track tight, rarely open trails with lots of good steep climbs, roots, rocks, ditches, creeks, logs, the good stuff.
95' KDX200
19" rear wheel/blk Excels
ported/polished head
FMF Gnarly
FMF Power Core 2
WNC
Post by WNC »
Just went to a 14 up front.
95' KDX200
FMF Gnarly
FMF Power Core 2
Road Dawg
Post by Road Dawg »
Renthal 13/48 and Renthal O-ring chain on my '03 220 ! :supz:
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." George Orwell
rbates9
Post by rbates9 »
Spartan'11
Post by Spartan'11 »
Im running a 15/47 combo as my bike is plated. Tops out at 78Mph by my Trail Tech Speedo, front end gets a bit sketchy though after 70Mph :shock:
Even with this tall gearing though the bike is still easily managed in the trail it does heat up quick in tight trails on hot days. As long as you keep an eye on the temp gauge though she's all good!
'01 kdx 200 Street Legal
Has thanked: 17 times
Been thanked: 24 times
I'm thinking I might actual switch to a 13/47 setup. 1st is already a granny gear and with a fresh engine with some additional mods I think I would be fine. Reasoning is I would pick up a little top speed that I need out here in the dez to run against the big 4T's.
David_L6
Post by David_L6 »
Just installed new chain and sprockets today. Went with 13/48.
BTW, 108 is the correct chain length. For some reason I ended up with a 110. Don't know if I was shipped the wrong chain or if I ordered the wrong size or if I thought I needed a 110 when I ordered (I've had the chain several months). You can easily use the 110 with 13/49 sprockets and probably 13/50. I'm going to have to take it back off and cut it to 108.
blimpman
Post by blimpman »
Bought a new set of front and rear sprockets and chain (110)
13/50 with a 110 chain will not fit.... So it is 12/50 till the chain loosens up a little.
It had a 12/47 set and a really stretched chain...
Brian
The destination is just a by-product of the journey
1990 KDX 200-E1 - Donated to my riding buddy Bill!
2003 YZ125
2008 WR250R
2005 TT-R230
DDR26
Post by DDR26 »
I have 2 KDX's, a 1990 and a 2001. I've been running 13-45 on both of them up untill now. Gonna try a 13-48 on the 01 next time. Just don't want to loose too much top end. Alot of the hare scrambles here in Florida are pretty fast.
Daytona Dirt Riders
1990 kdx200
2001 kdx200
2006 klx250s
onthepipe
Post by onthepipe »
Ran a 14/47 and it was too high
13/47 felt pretty good
just got a 51 for the rear...
if its too low ill throw the 14t back on the front
turtle
Post by turtle »
How many chain links are needed for the 13/49 combo?
Bill
Central IL
2004 KDX220R
2011 Triumph Tiger 1050 SE
Brian
Post by Brian »
I regeared my KDX to a 14/45 combo. I know it seems a little tall but I seem to ride mostly faster stuff, plus it's plated for the street.
FWIW I used a 110 length chain and I was able to use that length for my 13/48, 14/48, and 14/45 sprocked combo's.
David_L6 wrote:Just installed new chain and sprockets today. Went with 13/48.
Funny, I'm running the same gearing yet I think the 110 chain is way too short. My rear tire just touches my swingarm on the left hand side with just barely enough slack in the chain. I wish I had gotten a 112 link chain. I think I will go with a 47 (I thought that is what I bought for my build but somehow I messed up) just to get a little more space between the tire and the swingarm. Anybody have an idea of how much space it would give me?
CoronasAndChips
Post by CoronasAndChips »
This website will help you with that question. It will show you length adjustments as you swap sprockets. http://www.gearingcommander.com/
Elbow grease contains no trans fat!
CoronasAndChips on XBox Live
BFBC2, BF3, COD 2,3,4, Black Ops, Red Dead Redemption, Tiger Woods 08' and 09' and Forza 2..... mostly
CoronasAndChips wrote:This website will help you with that question. It will show you length adjustments as you swap sprockets. http://www.gearingcommander.com/
Thanks. I had never paid attention that it would show that info. Looks like I could gain 8mm of clearance and that would be about perfect.
CoronasAndChips
Re: What sprocket set are you running ??
It's all good..
pastorbuck
Post by pastorbuck »
Just recently changed from 13/47, to 12/47 to get a little more power down low. I ride mostly tight woods stuff. Not sure whether I'll keep it this way or not. Need to ride a few more times before I decide which I like better. 12/47 is very low. I can come almost to a complete stop in 1st gear without stalling it.
