Didn't work.
12mm should be correct. If you think that's too big, take a 12mm wrench and try to fit it on your kicker nut. Nut kicker? Yes, just do it. Hmmmm. It won't fit? Does it look to be about the size of threaded shaft protruding through the nut? Why yes, yes it does! Hrmm.... Perhaps the parts fiche is correct when it says 12mm? Surely not.
*edit*
Note to self: refresh before posting. Last post I saw before posting was indas post about "wording carefully", hence the "didn't work", and all the nonsense that followed in regards to something that's already been figured out. Oh well. I been on 24/7 call for a week, haven't slept in days, that's my excuse and I'm sticking to it.
Kickstart Retaining Nut
heckler
if worst comes to worst, which it might when looking for metric fine thread nuts locally
http://www.mcmaster.com
search for 90576A141
Metric Nylon-Insert Hex Locknuts—DIN 985
Thread M12
Pitch,1.25 mm
Width,19 mm
Height,12
Pkg. Qty 25
Fine Thread
Zinc-Plated Class 8 Steel
90576A141
$11.76 for 25 of them
The nylock will help keep your nuts where they belong.
Thread M12
Pitch,1.25 mm
Width,19 mm
Height,12
Pkg. Qty 25
Fine Thread
90576A141
