Wet Air Screw
Tomm9050
Wet Air Screw
For some reason, my air screw is wet. The carb doesn't pee, but there's a lot of spew coming out of the silencer.
Must be the float level, any other suggestions?
Thanks
Thanks
- Mr. Wibbens
How many turns out are you?
- Mr. Wibbens
I doubt that would do it anyway
- OLHILLBILLY
- OLHILLBILLY
Get yourself a shop manual, tells you how to do everything on your bike.
Mine cuts off at '95, and everything is different for the earlier models, right down to how to set the float level.
Meantime, do a search on the subject, I'm sure it has been discussed here sometime in the past.
2004 KDX 200.. Coupla mods
2009 KX250F.. Track Star
2007 Hayabusa.. Street Madness
- OLHILLBILLY
Set the float height to the recommended 16mm as shown in measurement #4, and you should be good to go.
My manual shows the "special tool" too, but I just set it by measuring it and all works fine.
The difference between the '95-up and the '94-back, is that the newer version has to have tha carb body angled when you measure the float height, so that it doesn't compress the spring loaded float pin. The older ones can apparently be level upside down to set the height.
- scheckaet
the lower one I believe
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
