Where to buy DEL needle, and recommended clip position?
DirtDaddy
I'm considering trying a DEL needle on my sons bike, 2006 200, all stock except air box lid removed. Currently running 152/42 jets, elevation 500-2,000 ft, temps 50-75 degrees. Bike seems to be running pretty good, but he complains about a slight bog right off of idle, usually in a technical section or starting on a hill, etc. Planning on playing with the air screw a bit to see if that helps. I've read here that the stock needle can be improved upon and it sounds like the DEL would be the best, ie: smooth power band, good for technical riding, enduros, etc. Now for the questions: Does the DEL sound like the right needle? Where can I purchase one? What clip position would be the best starting point? Any other suggestions on getting good response in the low end? Thanks much!
- ihatefalling
Jupiter2
- scheckaet
I would guess jets are jets...
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
