Yesterday I put the finishing touches on it, and fired it up! It took about 6 kicks, but that was to be expected for a brand new engine. It fired up, and I had to adjust the idle a bit (again, to be expected) so that's why you spend 30 seconds staring at my gonch in the video!
Some pics of the last installment of the rebuild!
Seat on, everything but side panels are on!
Temp stickers: Another one is on the left side of the jug.
Slick hourmeter install:
New carb lines:
Rads filled, transmission filed:
The "final piece" to the bike!
FIRST STARTUP!
Took it outside for the first startup, then after once around the block parked it to take some pictures.
Well, it IS a dirt bike after all, so it couldn't stay clean for long! Went out with fellow TT member Pumpkin450SXF and we tore up some trails. Had a few biffs on the way. I wish I would have gotten it dirtier, but it's pretty dry out here.
Initial impressions are very good. Bike has a TON more bottom end than it did before. I might also retard the timing to give a touch more over rev up top. When I say it has a TON of bottom end, I'm not kidding! I could easily ride a gear higher than I would usually, and going up hills, at even 1/2 throttle, you just hold it there and this whore will tractor right up it! Thanks to RB Designs for his majical carb and head mods that make that possible. I still need to check the jetting (might be a bit fat on the bottom) and fiddle with the airscrew a bit more. That's all to come. In the meantime, I'm glad to say that the build is finally completed, and the bike runs like an absolute champ!
