Black Spew...
Tomm9050
Black Spew...
With the new RB head, I seem to be getting a lot more spew, black crap out the back of the tail pipe.
Running 40:1 "smokeless" premix.
Any solutions to this??
Thanks
Thanks
- scheckaet
a little is somewhat normal. Is your silencer cleaned? did you rejet after getting the head from rb? do a plug shop test to verify your jetting.
Note: don't jet by the amount of spoo you get / don't get, I only mentioned it because it might be part of the issue. the only way to jet right is to do a plug shop test, Inda has a great tutorial in the jetting section.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
IdahoCharley
...."a lot more spew..."
With more efficient combustion due to the RBD head mod you may just be heating up the goop that had accumlated over time and you are now pushing it out the exhaust tip. I agree with check out the jetting and replace the packing (if you have a non-OEM silencer). More efficient combustion should lead overal to less spew - but of course you need to be jetted somewhat close to get the correct burn rate and the maximium power out of the engine.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
Yup... heating up the old spoo in the pipe and it will be nasty for a while.... mine is starting to calm down but for a while it was an insane amount.
Tomm9050
Gas/air mix is what determines rich or lean... less oil only makes the mix richer.
- fuzzy
