XR 400 springs
jrnolan
Forums were always the best source. Thumpertalk is a good one to ask on.... or a OEM Honda site.
NewMexico505
ADV rider is one of the best forums, great advise a mature. Here's a link for the section for thumpers, you'll have to look for the XR400 thread.
http://www.advrider.com/forums/forumdisplay.php?f=15
Here's a link for Sonic Springs, they are a little cheaper then some of the other manufacturers.
http://www.sonicsprings.com/catalog/ind ... 852613034b
Good luck...
Good luck...
OEM is BEST!
jrnolan
I am putting an order together from MotoSport, they have the OEM springs in stock for $30 per spring. I will do the 1' schedule 40 pvc spacer mod, 5mm preload and motion pro bleeder valves but have some conflicting thoughts on oil wt. and volume. Any advice on a starting point would be a big help.
Thank you in advance for your time.
Maybe this should be in the suspension thread, sorry.
JR
JR
Mix 5 and 10wt.... 7.5 seems to be just about right. You will need 2 qts anyway....
530ml approx. but is measured at 87mm + or - 2mm from the top of the collapsed fork leg.
This is measured with the forks completely collapsed and the rod pumped several time until there is no air in the forks. You will feel the resistance....
I should just say... refer to your manual.
jrnolan
Usable range is 87 - 100mm
All straight from the manual.
KDXsg
Hi inda, i weigh 150lb with gears on and have a 2006 kdx 200 stock fork on my 92' kdx 200. is it advisable to also change my spring to a xr 400? any considerations, if so what is the best spring rate for me? and why is good to change to the xr 400 spring? thanks for any advise.
A true KDX customizer!!
150 is borderline for any stock KDX springs... depending on the terrain. More like 135lbs is perfect for stock springs.
XR springs should improve your suspension... I would first try a heavier fork oil.
No... 95 and up conventionals.
Xr400 96-99 : .38
Depends on the year of XR400 they were for.... that's why I stated 96-99
