Does this sound right?
I adjusted (raised) my carb float level, bent the tang DOWN a bit, it was low, and when I put it all back together, it was not getting gas, gas wouldn't flow.
I lowered the float a bit and it seemed to fix the problem.
So, if the float level is too high, will it prevent gas from getting
to the bowl?
Thanks!
1992 KDX 200
stock needle
45 pj
155 main
3rd clip
Carb Float ???
Not really.... that sounds backwards of the way it should work. You really should measure it per the manual but add 1 mm to keep it from peeing.
- ihatefalling
