putting kips back togther
pinitwot
Post by pinitwot »
ok rebuilt the top end with wiseco piston.
now all i need to do is get the shaft that comes from the bottom end on the out side of the motor back on. it where the part with the teeth on it meet the main gear. (where it has the reversed threads)
i want to no if the part with the teeth needs to go on a sertin way? like to the left or right on top or to the right of it?????????????
thanks
i can post a pic if you dont understand what im talking about
scheckaet
Post by scheckaet »
post pics, cuz you no makin sanse. plz
bronco95tgp
Post by bronco95tgp »
There is a white mark on that little gear that you were supposed to make note of its position before you took it apart.. It has to do with timing and Im sure someone else will chime in with a more detailed response.
Maybe this pic will help.. there are four notches to choose from if I remember right, I put mine back in the 2nd from the right..
its a '04 KDX 220 cadillac
canuckhybrid125
Post by canuckhybrid125 »
scheckaet wrote:post pics, cuz you no makin sanse. plz
Be nice
It Is What It Is
2000 KX KDX Hybrid
2006 KX 100
2004 TTR 125 LE
2010 KTM 300
scheckaet
Re: putting kips back togther
Post by scheckaet »
I was...u gotta admit the description was a bit confusing...
where's Carv when you need him? :?
glad somebody could help though.
IdahoCharley
Post by IdahoCharley »
scheckaet wrote:I was...u gotta admit the description was a bit confusing...
You got a point - no one goes to the trouble that CC does to get to the point/problem in the thread that the poster intended. One of you guys musta pissed him off - I haven't seen him post in quite a while. The KDXRIDER community is missing out - IMHO.
CC you need to show up again - don't think I've seen a post from SKI-PRO for a while also.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
pinitwot
Post by pinitwot »
ok thanks
i think the pic of what bronco95top has is just what i need.
thats just how mine looked when i took it apart :supz:
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Both should be marked with a indented dot. Mine were and I have a 95!
pinitwot
Post by pinitwot »
ok well i worked on mine today and there is a notch on the top part ( the part that sits on top of the gear. but the gear has no notch????????
i dont no what to do. i put it back on so its the same as when i took it off. but not positive though.
does it still work if not in the right spot?
i will post a pic tommrow, but the pic by bronco95top is the part im talking about.
i should have just marked it when i took it apart :oops:
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
I'd be hard to screw up really.... If you turn it clockwise and you don't run out of gear before it stops... it's good.
pinitwot
Post by pinitwot »
ok i think i got it on right.
what will happen if its not on right though when i go to run it?
