How to clean carb?
JHNguyen89
How to clean carb?
Post by JHNguyen89 »
Removed the carb from the bike and bought some cleaner.
Removed the float bowl, jets, and needle.
Do I remove the float and float valve as well? And also, how should I go about cleaning it?
Mr. Wibbens
Post by Mr. Wibbens »
Better to remove the float and valve before that pin comes loose and you lose it :wink:
Tedh98
Been thanked: 2 times
Post by Tedh98 »
I take everything apart.
Even this thing that you need a security torx bit for
I soak it all in degreaser and then toothbrush all the grime and crud off.
I'll then use the carb cleaner in the can to blow out and clean all the passage ways. Finally I'll run some fine wire through the jets to make sure nothing is stuck in there.
RBD
Post by RBD »
The jet block o-ring/gasket in that pic looks shot and will not re-seal properly.
Ron
Tedh98
Post by Tedh98 »
RBD wrote:The jet block o-ring/gasket in that pic looks shot and will not re-seal properly.
Ron
Thanks, I'll get a replacement.
Has thanked: 15 times
Been thanked: 28 times
Tedh98 wrote:>|<>QBB<
Ron
Good luck! If you find some let me know, I need one too. Best bet is not to remove the jet block if you don't have to, and don't soak the carb body in anything that will damage that gasket. Keihin does not list it as a replaceable part.
