220 head on a 200 jug?
scheckaet
Post by scheckaet »
I know it's a dumb question, but are the head different?
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
The only dumb question is the one you already know the answer too...
They are different. As Ron Black stated, the 200 head is better than the 220 head on being machined to closer consistant tolerences than the 220 head.
scheckaet
Post by scheckaet »
just wanted to confirm, before doing sumthin stoupid :wink:
thx
zomby woof
Post by zomby woof »
So the heads are the same, but the 200 head was built to tighter tolerances?
Ontario, Canada
RBD
Post by RBD »
Let me clear up some of the confusion, the heads are not the same! The 200 head has a, "as cast combustion chamber" and not all that consistent between heads. It is not a machined surface.
The 220 heads start out using the same casting, but the combustion chamber is a, "machined surface" (3 mm bigger) and the spark plug hole is at a different height where it was spot faced for the spark plug seat.
The 200 heads start out with a little higher compression and do have a tighter squish band than the 220 in stock fourm.
All of this being said, the 200 heads are not very consistent and also have a higher compression ratio than the 220 heads. The 220's are more of a enduro set up head wise.
The 220 head is a machined surface and are very consistent. But are a little weak in the compression department.
Ron
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Thanks Ron...
johnyblaze
Post by johnyblaze »
Thanks Ron for a concise explanation.
1998 KDX220 with goodies
2002 KTM LC4E
2001 Suzuki Bandit 1200S
