I've got a 1991 KDX 125 (which I know the americans on here might not have heard of...).
I've read that new power valve and reeds can make a big difference. Is this true? Can it be done without spending too much poppy? Is it a fairly straightforward job? My mechanical skills are growing, but so far have only worked on 4-stroke engines (mostly Monkeybike and my rusty old Citroen 2CV..). Never torn open a 2-stroke....
Any advice would be appreciated!
-eli
KDX Power valve
- Has thanked: 15 times
- Been thanked: 28 times
You're in for a treat! Tearing down the 2t will be a dream compared to any 4t. The power valves only need to be replaced if they are worn or broken. New reeds can indeed make a difference. You'll want to check the piston and cylinder and make sure all is in spec. Replace the piston if it is worn, put new rings in regardless.
I have heard of your kdx 125, I knew they existed, but I have not seen one. They are not very common in the US at all.
- scheckaet
power valve, I would do a top end just to check the situation there, for all you know they might need a good clean up, as for the reeds, it's very easy to replace, pull carb, remove reeds install new one. done
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
DemonicOmelette
- scheckaet
have you tried this? http://www.cyclepedia.com/amember/go.php?r=57&i=l2
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
