USD Forks KYB 43U, 46U, or 48U?
SOARSKI
I don't think I did my homework as well as I should have. Im wanting to do a USD fork conversion and have a set of 96 kx 500 forks with rim. When I bought these six months ago I didn't realize these were a 43mm fork. I bought them because they were(I think) a direct fit to the KDX.
This is what I found, correct me if I'm wrong:
KYB 48U
- KX 125 2002-2005
- KX 250 2002-2005
KYB 46U
- KX 125 1996-2001
- KX 250 1996-2001
- KX 500 1997-2004
KYB 43U
- KX 500 ?????-1996
I'm wondering if I would be better off going for a KYB 46U or 48U? Any big advantages such as performance, getting parts and finding good info to rebuild the forks myself. I can find videos on rebuilding 46U and 48U but not 43U which is helpful for a first timer like myself.
KYB 48U
- KX 125 2002-2005
- KX 250 2002-2005
KYB 46U
- KX 125 1996-2001
- KX 250 1996-2001
- KX 500 1997-2004
KYB 43U
- KX 500 ?????-1996
- Has thanked: 15 times
- Been thanked: 28 times
That looks about right to me. I wasn't entirely sure what year they swapped to 46 from the 43's, but I'm pretty sure the 97 had 46's.
I would think the 43mm KYB USD's will be good forks for a KDX. Perhaps not as ideal as something newer, but still darn good forks. The rebuild will be pretty much the same as with the other forks, so using that video and an exploded parts diagram of the 43's should be all you need.
Also yeah, If you have the front end with triples and all, it should just bolt into your steering head.
- skipro3
I had a friend with a KX500. How he set up those forks, I'm not real sure, gold valves and someone set up his shim stack. Anyway, that was the plushest front end I've ever ridden. So smooth! If I were to set up a KDX, those are the forks I'd use. Bigger is fine if you're hitting big air on MX tracks I suppose, but for trial riding, I think the 43's would be best.
****EDIT****
I remember now; he bought gold valves and had the local Race Tech shop install them and set up his forks. He discussed the type of riding he did, trail bike, single track technical interspersed with some fire roads for quicker stuff.
****EDIT****
Jerry
river
Re: USD Forks KYB 43U, 46U, or 48U?
Would you terribly mind sharing where you found those videos? I could use looking at those in a big way. Thanks much...SOARSKI wrote: I can find videos on rebuilding 46U and 48U but not 43U which is helpful for a first timer like myself.
SOARSKI
http://www.motopowervideo.com
I don't have the fork or the shock video but maybe someone can chime in as whether they are worth buying or just relying on other sources.
I do have the Basic Maintenance video and I thought it was good, especially for new guys. I also have the Carb video. I'm not sure I like it as much, I still haven't decided. I think there is some good guides on jetting out there. I would use a jetting guide and info found here in addition to the video for jetting. I think there may be some video on youtube and some other sites like racetech for suspension. The Videos by Motorpower are for specific model shocks. I like this because I've never touched the internals of a fork before.
Guess you haven't explored this site much eh?
SOARSKI
I'm workin on it. Its not from a lack of effort. I just got finished reading about 75% of the General Q&A. The MF is loooong. Maybe I'm just not very efficient. I always feel like I'm going to miss something with the search engine.Indawoods wrote:Guess you haven't explored this site much eh?
I'm currently working my way through the fork conversion threads. So much info,new terminology etc., ADD?
I'll eventually catch up. Feel free to point me in the right direction and I'll read it.
There is a section on Jetting and a section on Suspension...
It is all I have ever needed as far as how to....
- Colorado Mike
Just a quick note on Ski's assessment of KX500 forks. I have no idea how the forks on that bike can be judged, since the ones I have ridden only have the front tire on the ground once every 50 yards or so. They are like jet skis made for dirt. Apparently there are people that can control the right grip on a KX500, I am not one of them.
I want one bad.
I want one bad.
Mike
'04 KDX220
'04 KDX220
Not videos... you actually have to read.river wrote:Alright dang it, sounds like a challenge. I'll find them videos if I'm here all night.
- skipro3
When I rode it, I had a strong sense of self preservation. Actually, the throttle was very controllable I thought. This KX500 was specially modified; it had a compression release to ease kick starting. But not just any compression release. This one was mounted on the back of the cylinder just above where the carb bolts on. This release kicked in after the piston traveled about 125cc's down into the barrel. To start the bike, you pull in the compression release lever mounted near the clutch lever. Hold it in and kick start the bike like usual. You feel the resistance equal to kick starting a 125. Once the bike starts, you can release the compression release any time. The bike will start and remain running with the compression release pulled in since it does have that 125cc's of power. This release mount above the carb goes through the cylinder's water jacket and is quite unique.Colorado Mike wrote:Just a quick note on Ski's assessment of KX500 forks. I have no idea how the forks on that bike can be judged, since the ones I have ridden only have the front tire on the ground once every 50 yards or so. They are like jet skis made for dirt. Apparently there are people that can control the right grip on a KX500, I am not one of them.
I want one bad.
The KX500 also had an auto-clutch.
Jerry
river
- scheckaet
check this, helped me understanding a bit of what does what in the fork. http://www.kdxrider.net/forums/viewtopi ... hth+height
As for pics, check the usd kayaba sticky in the fork conversion, there is a few pics
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
river
Thanks!scheckaet wrote:check this, helped me understanding a bit of what does what in the fork. http://www.kdxrider.net/forums/viewtopi ... hth+height
- fuzzy
Pretty cool Jerry. Seems being able to find TDC, good jetting, and just give a 500 a gook whack and they light right up. Of course stuck on a hillside or something would be nice to have such a convienince. I love the power of a 500...The grunt anyway. Just needs a 2 turn throttle cam
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
