Advancer Shaft Removal
- Varmint
I'm trying to the the cylinder off and I can't get a good grab on the bolt behind the advancer shaft. Will removing the little phillips head free up the shaft for removal? Will anything drop into the cases?
The manual doesn't even mention to remove the shaft!
Why would you have to remove it?
- Varmint
Got a pic?
- Varmint
- Varmint
I use an offset 12 point closed end wrench....
Take that clutch cable loose too and get it out of your way.
- Varmint
- Varmint
- Mr. Wibbens
Take right cover off?
- Varmint
- Mr. Wibbens
Re: Advancer Shaft Removal
BTW, If it is anything like an E you have to take the cover off to remove the shaft.VirtualVarmint wrote:I'm trying to the the cylinder off and I can't get a good grab on the bolt behind the advancer shaft. Will removing the little phillips head free up the shaft for removal? Will anything drop into the cases?
Once the cover is off your problem is solved
Just watch the shifter return spring and kicker spring when you go to put it back together
I never had to do that on mine.
- Varmint
- scheckaet
Use the hand torque wrenchVirtualVarmint wrote: How can you possibly torque that bolt on reassembly?
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Varmint
Brian
I use the torque wrench on the nuts I have access too and then put my box end wrench on them and feel how much force it takes to move them and then I apply about that much force on the nut I can't get the torque wrench on. Once you have gone around them a time or two they should all be torqued about even.
