Installing FWW and Clutch Lever on kdx220
Byte
how do i remove the flywheel nut while keeping the flywheel still?
how do I obtain enough slack in the clutch cable to fit a new clutch lever?
Byte
Byte
- Has thanked: 15 times
- Been thanked: 28 times
Have you got a service manual? If not, get one please and then use it. You're killing me slowly.
Clutch lever: There are 2 adjusters in the clutch cable. One at the lever, and one in the cable. Adjust them both to lessen tension on the clutch cable.
Flywheel: Use an impact wrench. OR put the bike in a high gear and use something to jamb the rear wheel. A bar through the sprocket resting on the swingarm will work. OR some people cram a rag in through the spark plug hole to stop the piston.
That's odd about the clutch cable. If you turn the adjusters on the perch just so, there is a slot that the cable comes out of. If the in-cable adjuster and the perch adjuster are loosened, it should come out of that slot.
The flywheel nut is your regular thread, lefty loosey, righty tightey. It can be quite a bear without an impact wrench, so block up the drivetrain however you need to and put some muscle to it. And merry merry x-mas!
- Mr. Wibbens
For the flywheel, I've used a Craftsman strap wrench
Just 'fer grins...
Is that a serious question? Surely you jest.
Maybe clocks move backerds down there? Is that why y'all are usually a day ahead of us?
Byte...you got 'troll' tattooed on yer 4-haid.
manual states fw nut is right thread.
does this mean i turn it cw or acw to loosen it?
Yes.Byte wrote: Now, the bike will not start - suggestions?
Byte
Although, the previous being a response expressly to juliend..I guess we'll wait on him.
...besides...a crv is some kind'a honda ain't it?
Maybe juliend got kilt slowly already....
Byte:
Did you remove the FW?
If so....
You took note of the woodruff key?
You checked for its presence after you installed the FW?
Byte:
If so....
- Mr. Wibbens
What happ'd to your Stalone avatar?
...wasn't Stallone.
but...you knew that.
I'm back with Joe!
I'm back with Joe!
- Mr. Wibbens
Looked more like Sly than this guy
You know Byte.... I am amazed that everyone is as accomidating to you with what seems like silly questions. Someone with no mechanical ability should not throw stones at those who are helping you....
This is why I stopped answering your questions long ago.
You know.... New Years is coming up.... think about turning over a new leaf.
