Hi all, years ago i use to send my pro circuit pipe to local repair shop to have it decarbonize and they actually cut the pipe open to decarbon and then weld it back. It performed great!! but after which I find it too costly, the backet attaching points are out a bit and i need to leave the pipe at the shop a few days for them to work on it.
I decided to DIY, things you need are a air compressor and a blow torch, a private open area and free of any flameable material around you.
1) using the blow torch, heat into the pipe opening at the exhaust spring side till red hot.
2) By this time the compressor is standing by beside you ready to blow air into the exhaust opening.
3) Till red hot, blow air into the exhaust opening, and you should see the carbon inside the pipe starting to burn by itself and travel up to the unburnt area bit by bit.
4) spark, flame and burnt carbon will start to shoot out from the other end of the exhaust opening.
5) do it till the burning stops. it mean no more carbon left inside.
6) there you have it, pipe decarbon at no cost, no cutting required and you can spray it black using high temperture spray paint or send it for nickel plating.
the key to success, be patient. do it in your free time. Jeryl.
decarbonizing exhaust pipe....it easy!!
Start a fire... throw the pipe in and let it cook is another method.
nearma12
I have heard that before. I think that is what I am going to try on my pipe. I just have a stocker, so a fresh coat of exhaust paint will make it look good as new afterwards. I would assume most people with after market chrome pipes wouldn't want to go that route.Indawoods wrote:Start a fire... throw the pipe in and let it cook is another method.
KDXsg
it really is subjective. for me looks is not so important so for my pro circuit pipe after a long time I m left with no choice but to decarbonize it for performance. its just that after which looks do i perfer. just plain black look or have it nikel plate but at a higher cost.
wish you success in your experiment!
A true KDX customizer!!
- Been thanked: 19 times
- kdxmaniac
wonder what that yellow smoke will do to your lungs??
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
