Not an "oil-thread" but about oil-ratios?
raisedinal
Can anyone point me to some good sites discussing how ratio's are decided on. I'm not objecting to what is accepted as an acceptable ratio. I already know what I'm going to use. Just wonderin what it's based on...performance, wear, or what ratio is the least sacrifice of both, or even spooge (sp?)
My maintenance is done...just a little education for the 2 stroke noob!
are Injection 2 stroke oils acceptable in mix applications?
Any good reading on 2 stroke oils as well?
Thanks Ya'll!
Thanks Ya'll!
I can point you to:
google.com
..where you can find out anything you want to know, all sorts of stuff you don't want to know, more than that of stuff that's bullpucky, and some that's just right.
Considering the tens of thousands of pages of opinion and even a few pages of fact (each sure they are correct) that are available for your perusal on the web (and this site) you can find whatever it is you're after.
You already know what you're going to use..so, have fun. You can keep busy for years reading about JASO oils, TCW oils, ash content, synthetic, castor, blends...
They're all the best, and they all work great...and if you don't use <this one> you're stupid.
google.com
- Mr. Wibbens
That oughta pretty much cover it
Well now... I think using products not designed for the application is a fools quest.
Remember when you were young and people would say... oh just use transmission fluid in your power steering pump.... same stuff!
What happened 6 months later? Power steering pump locked up.
For longevity... please just use the right thing. Oil is not something to cheap out on.
- zomby woof
NewMexico505
raisedinal
I guess stating an "oil-thread" or Oil-ratio's strike fear, dread and hostility?
canyncarvr: check out http://lmgtfy.com/ for the next time your asked a "google-able" question.... for instance http://tinyurl.com/yecbyzr, Good smart-assed way to answer!
I actually asked because I did google first ("2 stroke oil") and in this case and got every answer in the book. Someone said never use less than 20:1 for motorcycles, then others state use the manual. and around here the general consensus I have seen is 40:1.
BUT in providing CC the example above I ran across this: http://dirtbike.off-road.com/dirtbike/a ... ?id=400487 It came across as a reasonable and educated answer.
Guess I should have googled!
Now to google a good "Castor" based oil!
- zomby woof
This is what I use.
raisedinal
- Has thanked: 15 times
- Been thanked: 28 times
It's just that you may get more buildup and residue on the KIPS moving parts using a castor based oil. Unfortunately the kawasaki KIPS system does not take kindly to being gummed up. The little crappy aluminum gear teeth like to shear off leaving you with a non-working KIPS system and an expensive and irritating repair job ahead of you.
The KDX is really not a high RPM bike like say... a KX , CR or RM.... A KDX will build up much more than a race bike. Race bikes are rebuilt more often than a KDX too so cleaning is much more frequent also.
I would use a castor based oil if I thought it would keep the KIPS clean because ....damn I love the smell of it burning.
You did find one of the better articles on the subject which means my response had its intended effect.
'Give a man a fish....' and all that.
Congratulations on the find..and the motivation to keep looking after the first (..got every answer in the book..) attempts.
Thanks for that REAL google link.
Very good.
- zomby woof
