before the cutting
and after..i took it to a machine shop the one of my buddies works at and he cut the top mount off and drilled the rear case out all for only $20!
this is a 2000 model KDX 200 motor and how it lines up on the 99 frame..you could either shave the bottom of the case or cut the bottom mounts off..i opted to cut the mounts off as i didnt want to compromise anything by grinding anymore on the case
swing arm cut and mounted!
this is a pro circuit platinum pipe i bought off ebay. it fits, but we did have to weld in a 10mm section for it to clear the front of the frame. it still has to be dented..in two places believe it or not..one is by the radiator and the other is by the harness for the clutch cable on the motor
motor mounts getting fitted and refined for welding
tacked on with a tig
thats all i have for now..ill have more up soon!
