Front and Rear Tire Pressures
Byte
Post by Byte »
Both my tires have gone flat over long periods of non-use.
What should Front and Rear Tire Pressures be in this KDX220?
MAXXIS tires used.
ANd, spec says 0.7L but how much gear box oil is ideal in the case?
Byte
KarlP
Post by KarlP »
You can use the full quart of gear box oil. It'll be fine.
The choice of oil has been discussed a few times.
I run 8.5 psi rear and 9 front. I'm not telling you to do that, because I've been told over and over that I'm going to get a flat. Maybe one year, if I do get a flat, I'll change my ways. A lot of people run ~12 psi. I find that too hard and slippery. 15 psi is like riding on ice, to me. A lot depends on your riding area.
You do need a good gauge to read motorcycle tire pressure. Most standard tire gauges don't read very well that low.
You asked earlier about the fuel petcock- handle pointing down is fuel on.
You also mentioned your exhaust not sealing up into the cylinder well, you thought. That is an easy fix. Look around on here, I think someone else just went 'round the block on that. Not sealing should not effect compression when kicking, though. You sure you put your sparkplug back in? :grin:
'08 KTM200xc
KX100 for the boy
plb
Post by plb »
Tire preasure:
It'a personnal choice, but for me, it's 11 for the front and 14 for the rear.
MXOldtimer
Post by MXOldtimer »
plb wrote:Tire pressure:
Yeah, I run 12 in the front and 8 in the rear and if I know it's gonna be rocky I'll up the front a couple pounds.
04 KX-250 Hey.....at least it's green and smokes.
06 KDX-200 for off road play. Gone but not forgotten
07 KX-250F SOLD! I thump no more.
Mr. Wibbens
Post by Mr. Wibbens »
12 psi front and rear
Always rocks here
kdxquebec
Re: Front and Rear Tire Pressures
Post by kdxquebec »
Byte wrote:Both my tires have gone flat over long periods of non-use.
A week? a month?
Remove the spring valve assy in your tubes and clean them maybe they are dirty. Then put 30psi on both tires and let them sit overnight. When the morning come...go in the garage for a check. (if you have not slept in the garage)
Take the result. And decide if your tubes are junk or not.
canyncarvr
Post by canyncarvr »
Re: 'Both my tires have gone flat over long periods of non-use.'
Not uncommon for tubed tires..and certain to happen if you use natural rubber tubes over butyl.
Has thanked: 11 times
Been thanked: 15 times
12 front, 10 rear.
Byte
Post by Byte »
great replies - thanks guys.
Byte
Has thanked: 9 times
Been thanked: 17 times
I run 12 up front and 7-9 out back depending on conditions. I have a trials tire out back though, that does make a difference.....
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
Mine works best flat.... I have proven this. :cool:
Varmint
Post by Varmint »
I just rode 28 miles of rocks, mud, roots and leaves and had some of the best performance ever running 8 and 7 :shock: . Of course I checked the pressure right after getting off the trail, so I may have had a lucky day. I would normally run 12/10, but man low pressure kicks arse in the nasty stuff.
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
kawagumby
Been thanked: 3 times
Post by kawagumby »
Lots of big square-edged holes where I ride, I need to run at least 13 front and rear or my tubes get pinched, and that's with heavy-duty enduro tubes.
fuzzy
Post by fuzzy »
LOL, yeah I loved my Maxxis at 2psi.
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
