KIPS noise?
john castaldi
KIPS noise?
Post by john castaldi »
everyone is talking about it, but not sure if I got it......
03 200 H9, everything new - crank, cylinder, pro-x piston, crank brgs, everything. Sounds like a piston knock, mostly idle. Not the clutch, I know that sound. Runs awesome!
So what does this famous KIPS rattle sound like, and what exactluy inside is rattling? What can I remove, hold, or whatever to make it stop so I can test the theory? (can I take the valves out and run the engine to see if the noise goes away?)
thanx
kdxquebec
Re: KIPS noise?
Post by kdxquebec »
what sound do you hear?
john castaldi
Re: KIPS noise?
john castaldi wrote:03 200 H9, everything new - crank, cylinder, pro-x piston, crank brgs, everything. Sounds like a piston knock, mostly idle. Not the clutch, I know that sound. Runs awesome!
thanx
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
The KIPS sounds like a rattle... but when the clutch pulled in, it starts to sound more like a knock on mine.
john castaldi
there is noise in teh primary gear, I know that one (some call it clutch noise) but this sounds like a wrist pin or piston slap.... but I've ruled both of them out.
KarlP
Post by KarlP »
Mine has always been kind of "Knocky" sounding.
I don't worry about it anymore.
Exhaust leaks can make strange noises.
'08 KTM200xc
KX100 for the boy
kaptiankent
Post by kaptiankent »
On my bike, an 05 220 I started to notice a rattle or knocking sound coming from the clutch side. I have had my bike for a few years now and it has been getting louder as time goes on.
The tone of the rattle changes when you pull the clutch in.
So I decided to pull the clutch cover and have a look.
What I noticed was the assembly that has the bearing and the pin that pushes the clutch in has a fair amount of side play. And this would account for the change in the rattle tone when the clutch is pulled in, since there is pressure on it when the clutch is in. The bearing was still tight and not worn.
Just to see if it was that I removed the end assembly and put the cover back on and started the bike. The loud rattle was gone. I could still hear the kips noise but it's quiet compared to the clutch bearing rattle.
I think its just the loose fit of these parts that causes most of the rattle and knocking noises.
Anyone else notice this on their bike?
kevfort19
Post by kevfort19 »
yeah me it's the same thing, it'S a bearing in the clutch side. when i pulled in the clutch the sound stop, the engine ran like a clock:P
KDX 220 2001 =)
Don'T drink and drive...just give some gas and fly :D
