13/49 gearing
jbowens2401
13/49 gearing
Does anyone know if I can run 13/49 gearing with the stock chain on a 2005 KDX 220? I think 12/47 will be a bit low for me.
Thanks,
John
Thanks,
John
Proly take a 110....
jbowens2401
- jaydollar
if the stock chain is streched,it will work,a.k.a. snails are on the big part of the cam...past 7 or 8.try this For a good chain.EBAY item #170127251875.thay also have 110 link if you look in their store.i have been running one for years with no problems.also jt steel sprockets on ebay for $25.00 from lytle racing.J$.
1999 kdx 220
rb carb, rb head pump gas mod. 607 reeds, airbox lid drilled
fmf torque pipe
fmf turbine core Q
trail tech endurance computer
13/49 gear
fmf torque pipe
fmf turbine core Q
13/49 gear
jbowens2401
- jaydollar
no prob jb.mostly tight single track with a lot of ups and downs.stock gearing 2nd and 3rd seemed a bit to high,the 49 made it perfect for me with no real noticeable loss in the top end for the occasional fire road,J$.
1999 kdx 220
fmf torque pipe
fmf turbine core Q
13/49 gear
fmf torque pipe
fmf turbine core Q
13/49 gear
jbowens2401
jbowens2401
update
I installed the 49t sprocket last weekend, and really like the combo (13/49). 1st gear isn't so low that it's unusable, and the gearing ratio seems to be much better. I think 12/47 would have been a little low. Also, I had to add two links to my chain (108 to 110), and my snails are on 7.
That must be one stretched out chain!
