jetting
pinitwot
jetting
Post by pinitwot »
i got an 01 kdx 220 and it has a fmf ganarly and a turbin core 2 silencer on it ;also it has the air box lid removed and a uni air filter installed. i am at about 200 ft above sea level. it has a number 160 main jet. does that sound in the ball park, is that the right jetting?
also after each ride there is a line of spoge or what ever u call it that runs about half way down the silencer is this normal or is the bike just a little rich, it runs good with no bogg.
also any tips on getting the carb. bowl screws off with out strippping them? them things are on there good!
doctord23
Post by doctord23 »
A 160 jet is stock for the 200 35mm carb but would be really rich for a stock 220 33mm carb. Maybe the previous owner changed carbs to the 200 carb. Check the pilot jet. If it is a 48, then I bet that is what happened. You can try a leaner main jet 158 or 155, but it is all trial and error until it runs the best.
I run a 155 and 42 with a 35mm carb on my 2000 220, but I'm running at over 5000 feet.
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
A 160 is way fat for a 200 too!
A 155 or 152 is a better bet for a 35mm carb.
pinitwot
Post by pinitwot »
polit is a 45
where on the carb does it say what size it is ?
is the spoge meaning it is a little rich?
porterdog
Post by porterdog »
pinitwot wrote: is the spooge meaning it is a little rich?
Really what it means is that your combustion temperature is too low, and that's a byproduct of a too-rich mixture.
