What's still in there?
Looks like the outer race of the bearing.
What's missing from the pieces you took out? Anything?
With that race out, my WAG is that you'll be fine.
Those Uni Traks are spendy.
From RonAyers:
Part Number: 39007-1229
Description ARM-SUSP,UNI TRAK
Price $125.87
TAKE THAT!!!
So much for gentle.
Get that shell out...I'm thinking you'll be fine.
This is a good object lesson, folks.
If you think a dirtbike is a machine you put fuel in, ride, and forget about it..you would be incorrect! Some have described dirtbikes as a 'blackhole for $$$'. Yeah. Pretty much. They take not only a fair number of $$ to keep in shape...but
more than a fair amount of time. I spent most of yesterday dinking with my bike. Cleaning it from the last ride, resetting the handlebar iso-cones, resetting the forks in the triples (I ran over a CRF that decided to flip a u-ey in front of me), replacing the top brake line guide (which included taking the brake line off..which led to a system bleed), adjusting my aluminum kickstand mount (shortened the inner collar, added a washer to tighten the slip-joint), replaced the oil in my WER, cleaned all my air filters, cleaned the air box (which was preceeded by an overhaul of my twinair airbox cover that's never fit worth a crap..but it does now..glued a piece of window screen bead into the removed seal to get a touch more depth, glued it all back together)....
...and that's the short list.
Aren't dirtbikes fun!!??
Oh...and if you happen to be a rider who has some family member take care of your machine (Hubby? Dad? Mom for that matter!), remember to say 'THANK YOU' once in awhile.
...couple times after every ride should cover it.
![Wink :wink:](./images/smilies/icon_wink.gif)
