Output Shaft Seal Remover
- pjmac28
Blew out my output shaft seal this past week. Cyclepedia states with picture (below) to use a 'seal remover'. Have been searching but nothing to this point in locating one (Autozone/Harbor Freight/NAPA) or I/Cyclepedia has the terminology wrong. If there is another way without the tool that would also work.
That is a seal remover....
porterdog
Re: Output Shaft Seal Remover
Back to googleschool with you!pjmac28 wrote:Have been searching but nothing to this point in locating one (Autozone/Harbor Freight/NAPA) or I/Cyclepedia has the terminology wrong.
http://www.harborfreight.com/cpi/ctaf/d ... mber=35556
- MXOldtimer
So, no one is going to admit to using a screw driver to pop'n the seal up enough to get a hold of it with a needle nose pliers???? Worked on a Yamaha I..............I mean, someone had.
Be gentile putting the seal back in press'n "evenly", they wont take any abuse. I used a large socket that matching the size as a driver.
04 KX-250 Hey.....at least it's green and smokes.
06 KDX-200 for off road play. Gone but not forgotten
07 KX-250F SOLD! I thump no more.
- Varmint
So Jewish folks aren't allowed to replace this seal? Are they non-Kosher?MXOldtimer wrote:So, no one is going to admit to using a screw driver to pop'n the seal up enough to get a hold of it with a needle nose pliers???? Worked on a Yamaha I..............I mean, someone had.
- kawagumby
- Been thanked: 3 times
another kosher-approved method is just to drill a small hole in the seal face, screw in a sheet metal screw and pull the whole thing out with a pair of pliers - that method keeps the case surfaces relatively safe from gouging.
- pjmac28
I didn't think of the tap/screw method, probably because i thought the width of the seal was to narrow to recognize that method(to scared to use the screwdriver method. Mite poke meself in the eye
) Suppose I'll just wait anyway since I ordered the puller, might as well get my $$$ worth since it more than likely will not be used again unless my father needs some type of rudimentary tool for birthing calf's since that is what it looks like.
- m0rie
- MXOldtimer
Then, you'd best put it back in.Wait.. that came out wrong.
- Has thanked: 13 times
- Been thanked: 24 times
Yes, yes. Where did that go again?? I should probably hope you don't answer that.
Anyway, now we have another good reason why I should not drink and post. Friends don't let friends post drunk!
On a more serious note, I would like to hear a report about how that seal puller works. I always seem to be that guy that makes do without the proper tools......
Every man needs a proper tool.
